Question about Palm Tungsten E2 Handheld
Palm Charging Tungsten E2 Will not charge fully.
  • 94 Answers
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Posted on Jan 11, 2008
Screen is blank
Your Tungsten might not be able to hold a charge. Try charging it for 3-5 hours and try again.
Jul 30, 2010 | Palm Tungsten E2 Handheld
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
Tungsten 2E battery will not fully charge.
Your E2 is showing a battery that is just about dead. Luckily you can replace it
Aug 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Synchroniz my palm pilot to my hp computer
you need to connect via bluetooth belkin is probably the best at around 10gbp from argos follow set up guide fully and it will connect to your computor no problem
Jan 08, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Palm Repair
If does hold a charge although it take al long time to charge and there have been eposides wihter I have lost the dates on the calander without reason. Thanks
Jun 20, 2008 | Palm Tungsten E2 Handheld
Is this a battery problem?
If it's not the E2 going to sleep mode ;-), have it checked by a Palm service center .It might just need a new battery. Worst case scenario the charging system is faulty. Have it checked.
Hope that helps. Let me know how you make out.
Jan 19, 2008 | Palm Tungsten E2 Handheld
Tungsten E2
Have you tried pushing the reset button on back to see if it comes on?
Nov 26, 2007 | Palm Tungsten E2 (Multilingual) Handheld
I can't get my Tungsten e2 to turn on.
Open up casing to reveal battery. disconnect then reconnect battery connection to mother board.
Nov 14, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
494 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
