Question about Neff B1428 Nostalgic Single circotherm Oven
The timer on the oven will not allow me to use the over manually
We have inherited the unit in a new house and cannot get the oven to work
  • 3 Answers
SOURCE: inherited oven without instruction manual
Try phoning the Neff spares department on 08705 543210
Posted on Apr 25, 2009
0 characters
1 Points
Inherited uncle's house that has an old electri-clean cookmaster oven. the element is not working but the fan comes on when you turn in on...can't find the serial number to get the look for correct part or...
Sorry to read about your problem, I hope this helps you out.
without the model number, you will need to have a service company, come and look at the unit,
tell them on the phone, that you dont have a number, and to send their most experienced person. then they can match a coil up....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Frigidaire 24" Built-in Single Electric...
Where can I get an instruction manual for a Maxol Majestic Duo Gas Oven? Thank you
please advise e-mail address as tried to attach first 7 pages
Jan 01, 2011 | Ovens
I have double oven my lower oven is not working appears a code in the screen that is not allowing to work the lower oven i restart unit in the code disappears but letter around cameback the code to the...
The exact same thing just happened with my lower oven and the code 4d22 appears in the upper right part of the display panel by the the timer. There is no explanation for the code in the instruction manual. Hope someone can help us with this. Upper oven works fine.
Dec 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Jul 14, 2010 | Ovens
Oven timer goes off randomly
I would suggest that a new timer is needed.
Dec 07, 2008 | Jenn-Air Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
good for 60 days only
Nov 09, 2008 | Belling Ovens
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Neff B1428 Nostalgic Single circotherm Oven Logo
Top Neff Ovens Experts
Are you a Neff Oven Expert? Answer questions, earn points and help others
