Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Wheres the compartment to change the battery its a logitech wireless mouse
@JSShears, this isn't a simple battery compartment. It requires that you remove the two rear glide pads, then peel back the label just to the left of "FCC" and just to the right of the crossed-out garbage can.
BEFORE you do this, realize that you may not be able to find a suitable lithium-ion battery that fits (and works) AND that you may not be able to adhere the label and glide pads to like-new condition.
The battery is custom for Logitech, labeled "L-LB2", specs are 3.7V, 1700mAh.
Since the unofficial "replacements" range from $30-40 plus shipping, to $10+shipping+soldering....it may be cheaper to buy a new mouse.
Posted on Dec 16, 2009
  • aleghart Dec 16, 2009
    For tear-down and re-assembly advice from a real-world project, see here:http://eviltyrant.com/blog/?p=914
    NOTE: the OP's first attempt to solder directly to the battery trashed the battery completely. You'll have to solder to battery contacts, and epoxy them to the plastic interior of the mouse.
    Not an easy job, even for a DIYer.
  • 3 Answers
Look on the bottom of the mouse. This is where the battery compartment should be.
Posted on Nov 17, 2009
5 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: wireless logitech mouse does not work
Going from memory, I think you have to remove the small rubber pads on the underside. On some types, you would also have to remove the model label on the underside. This should expose the screws to take it apart.
The cordless mouse uses Lithium chargeable batteries. Don't put standard type non chargeable batteries inside.
You may find the cost of the proper batteries to come close to the replacement value of the mouse.
Jerry G.
Posted on Apr 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
  • 116 Answers
SOURCE: change battery mouse 1056
most modern battery compartments are hidden with stickers on the bottom...peel back the sticker(s) slightly and expose the screws. or you poke through the sticker if they have indentations so that you can service them again with a bit more ease.
Posted on Mar 14, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
Posted on Mar 28, 2009
How do you turn on a wireless mouse
When you flip the mouse upside down you can locate a battery compartment, please insert a battery in it appropriately. Then next to the battery compartment, you will notice a green button which can be pressed or slided (according to different model) to switch the wireless mouse on.
Please specify the exact model number so that we can show the schema of the mouse from the manual.
Feb 15, 2011 | Logitech Cordless Mouse
Logitech mouse frozen up we changed batterys in
If the mouse is freezing up though the batteries are fully charged, here's what you need to do:
1. Try to use different batteries just to make sure that it's not a power issue.
2. Connect the wireless USB dongle into different USB ports of the computer.
3. Try to connect the USB dongle in different computer and try to use the mouse (to make sure that it's not a computer issue).
4. Make sure that there's no cordless phone, cell phone and other wireless devices that might interfere the wireless signal.
The Logitech wireless mouse is running on 2.4MHz frequency, same frequency as the other wireless devices. Any wireless device might cause the mouse to freeze.
If same problem occur, then it's a hardware problem. Contact Logitech and RMA the mouse.
Thank you and good luck!
Apr 18, 2010 | Logitech Cordless Mouse
Wireless EX110 Logitech mouse not connecting.
Try the mouse on a different computer. If it can't work on there then you may have a defective mouse. Contact logitech about warranty info.
Feb 01, 2010 | Logitech EX110 Mouse
My battery is down wireless mouse. Does it also
Battery compartment on the bottom of the mouse and beneath the keyboard.
Dec 17, 2009 | Logitech Wireless Access Duo Optical...
I do not know how to open the battery compartment
On my Logitech wireless mouse, the battery cover is on top.
Hold the front (switch and roller ball section) in your left hand then put your thumb on the Logitech symbol/name on the top cover and move/slide the cover to the right. The back section of the mouse cover top should slide off exposing the battery compartment.
Hope this helps! Dan
Aug 20, 2009 | Logitech Cordless Mouse
Mar 28, 2009 | Logitech Cordless Mouse
Change batteries in my wireless mouse
There should be a battery compartment on the bottom of your mouse. It might have a small screw holding it in place. Open & remove old battery, replace with fresh battery. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Went onto laptop today and mouse is working - don't know why !
Sep 10, 2008 | Logitech Cordless Mouse
Asus logitech wireless mouse
yah.. if your mouse has battery compartment,, it actually need a battery,, without the battery it will not work..
Dec 27, 2007 | Logitech Cordless Mouse
The battery is under the top side of the mouse; use the tip of your fingernail to lift it up, pop it off gently; then you will see the battery inside.
Nov 02, 2007 | Logitech Cordless Optical Mouse for...
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
487 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
