Question about Kitchen Ranges
I am trying to find parts for the Amanaa First
Where do I find parts for the Amana First Edition Electric Range 35-315017-05-0. I need knobs and the bottom storage drawer
SOURCE: We just bought the KitchenAid
There is no warming drawer, only the YKERS807 has the warming drawer
Posted on Sep 24, 2008
  • 98 Answers
SOURCE: AMANA ELCTRIC RANGE ARR6202 ALL THE TOP BURNERS
i believe they are fused. so i would say follow one of the wires and see if there is a fuse somewhere
Posted on Jun 07, 2009
woobie dog
  • 1273 Answers
SOURCE: Need new range top knobs.
They sell these at appliance parts supply houses. Take you old ones with you, and you should be able to get genuine replacements!
Best regards, --W/D--
Posted on Aug 08, 2009
delpolito54
  • 44 Answers
SOURCE: amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
Posted on Sep 01, 2009
marka19
  • 1430 Answers
SOURCE: The storage drawer on my range won't slide properly.
Enter your model # at www.appliancehelponline.com for diagrams and illustrations. The plastic pieces are under the body parts diagram on the left hand side.
Posted on May 03, 2010
Unlock oven door on amana ACF4225AW ?
Below is a link to sears parts direct. You can download an owners manual. See parts diagrams and order parts.
After cooling the oven door should unlock.The lock mechanism shows on the second link to cabinet parts.
The switches on the lock are sometimes the cause.
Good Luck.
Manual Amana Electric range ACF4225AW PACF4225AW0
Link to cabinet parts.
AMANA Electric Range Cabinet Parts Model ACF4225AW PACF4225AW0
Aug 24, 2014 | Kitchen Ranges
Ihave a amana range getting F1 code and it keeps beeping what part do I need to order to fix this? I love this range except for that!! An dwher can I get the part or should I call a repairman? Help!!
F1 points to the ERC or electronic range control. There are three different variants of this model. Here is a site that distributes Amana parts. Please select your specific model.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ACS7270
This is only a suggestion take it as you will. Good luck!
Jun 12, 2011 | Amana ACS7270 Electric Kitchen Range
Aug 08, 2009 | Kitchen Ranges
Broiler turns on all by itself. what can I do?
Hi, maybe your knob is broken, and it look as if it's off, remove knob and manually turn off , or you could have a faulty thermostat, or faulty circuit board, if knob is broken, you are smart, you can buy one and replace, if faulty thermostat or circuit board, you will need mechanic to check. good luck.
Aug 05, 2009 | Amana AER5715QAS Electric Kitchen Range
I have a amana Electric smoothtop range and the door wont close due to my child standing on it so its bent. Im trying to figure out how to take the door off and fix the hindges my self?
you will likely need to replace the hinges part # 74010546 (requires 2) , which are $26.00 each and are located inside the door. The door would need to be removed and then taken apart. Also you may need hinge receivers which are part # 70010551 $7.09 each. These are located on the oven cabinet and can be accessed once the door is removed.
Apr 09, 2009 | Amana AER5715QAS Electric Kitchen Range
Broiler element broke and was burning as if it was being welded
Probably none. The sparking going on after you turned it off was probably the ground side of the element. Replace the element then re apply power and see if you have any trouble then.
Apr 06, 2009 | Kitchen Ranges
We have an Amana ARDS802. The oven was on and we heard a click and now the oven has no power. The range top and exhaust fan still have power. Have checked the circuit breaker and not the problem. What...
You might check the oven control on the inside to see if any wiring, clamps or washers may have busted off te knob/control. Since the exhaust fan and stove still work, I would say the problem is only in or near the oven control.
Nov 29, 2008 | Amana ARDS802 Electric Kitchen Range
Jenair oven valve knob
In less than 6 years of normal use, 4 burner control knobs on my Jenn-Air free standing gas range, Model JGR8875QDS, have either broken or melted.
If you want to continue to buy Jenn Air knobs, no problem - several suppliers will be glad to provide them for  $10-15, each (USD). Whirlpool's part number for the factory Jenn Air knobs is 74009148, and you can get them from repairclinic.com (#1035396), or PartsSelect.com (#PS2086597).
If, however, you want to try a different set of knobs, hoping to find some that are less prone to break or melt, then it gets a lot more complicated.
Jenn Air/Whirlpool will be no help; they will tell you the only knob that will work is the Jenn Air OEM knob. Parts suppliers won't help you either - no specifications or interchangeability data exists - and they are unable or unwilling to take measurements.
I can tell you the following 3 knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
Dec 22, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Kitchen Ranges Logo
317 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
