Question about Logitech Cordless Mouse
The optic light is off,how do I troubleshoot - Logitech Cordless Mouse
  • 4,806 Answers
Start by changing the battery for a new one. If the optical light comes on then press the connect button under the mouse and press the connect button on your receiver,.
To activate the mouse just right click.
If you have changed the battery and it's still not working then clean the contact in the battery housing on the mouse and try again.
Regards
Posted on Nov 16, 2009
Avr 335 no red lights in optical sockets
if they are optical inputs, then there will not be light coming out of them. the light should be coming out of the optical cable that runs from whatever source you are trying to hook up
Jan 04, 2015 | Harman Kardon Audio Players & Recorders
Sound from my plasma TV does not work on AVR 235 via optical cable
So much can go wrong. WARNING!! NEVER LOOK STRAIGHT INTO THE LIGHT FROM AN OPTICAL AUDIO OR VIDEO SYSTEM. The optical output could be not working (try switching it on and look if you see a red light) The optical cable can be broken inside) see if the brightness of the red light is almost the same as what is coming out of the TV. Point it to a white paper to view.
The optical input from your receiver can be defect or dirty. The optical protocol can be wrong or the systems are not compatible.
If it ever worked, the most chance is the cable is defect.
Otherwise follow the chain and read what the manuals have to say about how and what.
Nov 30, 2014 | Harman Kardon AVR 235 Receiver
Pro-Form 545s......pushing speed #1 starts at 1.6....#2 starts at 3.2 and so forth
1) The normal functions is gradual o.1mph and so on until you reach the maximun speed.
2) check the speed sensor
http://www.youtube.com/watch?v=23ZgWaVEQjA see this videos and test the speed sensor and change if is faulty.
If LED does not light, inspect:1. Optic sensor signal wires and theirconnections; Reinsert wire ends into connectors.2. Whether optic sensor wheel rotates in themiddle of the sensor; If not, reinstall the optic sensor wheel.3. Whether optic sensor wheel teeth are brokenor bent; if so, replace the optic sensor wheel.4. If LED2, the VCC circuit indicator, on thedrive board lights and there is no optic sensor signal output(LED does not light), andif optic sensor wires and connections are good, replace the optic sensor.
2a) The main motor you must test:
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
3) otherwise is o.k you must replace the display board.
Nov 13, 2011 | Exercise & Fitness
My treadmill was going slow and speeding up and keeped doing that when I would start it. Now it won't run at all! Do I need a new motor or is it the wiring?
Optic Sensor MOTOR Signal Test Procedure
Turn on unit power. Do not press display keys. Use your hand to rotate the motor flywheel. Normal result:
LED 10 lights to indicate the optic sensor signal entering the drive board. The LED appears to flicker at a
low speed and remain lit at high speed.
Optic Sensor MOTOR Signal Test Results
If LED10 does not light, inspect:
1. Optic sensor signal wires and their connections; Reinsert wire ends into connectors.
2. Whether optic sensor wheel rotates in the middle of the sensor; If not, reinstall the optic sensor wheel.
3. Whether optic sensor wheel teeth are broken or bent; if so, replace the optic sensor wheel.
4. If LED2, the VCC circuit indicator, on the drive board lights and there is no optic sensor signal output
(LED10 does not light), and if optic sensor wires and connections are good, replace the optic sensor.
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Oct 01, 2011 | Proform 380 CS Treadmill !
Can I See in Dark Room where light is off. Any device , Camera, Optics are available in market. if available please suggest me. and sent me rates of these.
Hello. only if there are some ambient light source. Very light glow. In the dark room with no light you would be luck see you had. It take light to activate the thin plates in the image tube. Check with Night Owl Optics in El Paso, TX. You can check with the large Optic Lens Companies and see what the have to offer. You'll need to get the diameter of the lens opening, thread size in which it will be in mil-meter mm . stewbison
Jan 28, 2011 | Night Owl Optics PVS-7U Goggles
Where can i use my Optics Explorer NOCX3 at.
Hello, at night! Please don't use your Nigh Owl Optics to look at light, bright lights, street lights, just use it in the DARK!!!. If it to dark to see throught your Night Owl NV turn on the IR illuminator. Then you can see in those dark rooms, and sneak up on your friends. GB...stewbison
Nov 24, 2010 | Night Owl Optics Explorer NOCX3 Monocular
What is the difference between a light engine and optical block?
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
Nov 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Optical engine for akai pt50dl14
Here's a link to order the original Akai light/optical engine for this model (PT50DL14) from a major parts distributor:
Akai Samsung PT50DL14 Replacement Part Light Engine / Optical Engine Block
Feb 17, 2009 | Televison & Video
Kitchenaid # KSRA25C
Some precautions before diagnosing the icemaker optics system since there are two different sets of emitter-receiver optics boards and therefore two entirely different procedures for emitter-receiver optics board diagnosis. This could get really tricky especially when the appropriate tech sheet isn’t handily available. To determine which optics diagnostic procedure should be employed, open the freezer door and observe the right side (mullion or partition side) LED status light. If the red LED is NOT flashing two repeating pulses, this usually indicates the older style emitter-receiver optics boards are used and its specific diagnosis procedure should be employed. But then again, this could also mean that the new optics system IS used but the icemaker just happens to be in the harvest mode - OR - the LED (optics receiver) has failed in some bizarre twist of fate. However, keeping the above cautions in mind, we can assume that normally the older emitter-receiver optics system will NOT have its red LED status light flashing each time the freezer door is opened, while the NEW style optics WILL have its red LED status light double pulsing at each door opening.
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Logitech Cordless Mouse Logo
91 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
