Dide you set up the wireless on your router? If you have done this and you have it set for None for security, you will also be "unsecured", BUT you still have a name (SSID) to identify your network. Check that your internet is set for "Private" access, if you are presented the option between Private and Public.
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
At the bottom right hand corner of your screen, you have a wireless connection icon. right click and view available wireless network...if you see your network there. connect to that network, if secured, then call d-link to verfiy what is your network key. if it is unsecure then you can log on right away.
if that wont allow you to connect then upgrade firmware of router.
