Question about Sewing Machines
How do you use a toyota sewing machine model 2701 series ec1? it's threaded correctly, but am not sure what setting to use to sew in a straight line please help
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 12 Answers
SOURCE: Bobbin thread breaks
Things to check for thread breakage (top or bottom)
1. Good thread in the machine - not hand thread, cheap thread, quilting thread.
2. A burr on the hook - a small nick on the hook can grab and tear threads, however this usually causes the top thread to tear, not the bottom
3. Make sure a new needle is in the machine - one made for the material you are sewing
4. The bobbin must be installed to rotate in the correct direction in your bobbin case
5. And I'll say it anyway - tensions - the primary cause of thread breaking - Remember, there are TWO tensions in a sewing machine, top and bottom. Also, the thread you see on the bottom of the stitch is the top thread, and vice-versa.
Posted on Dec 04, 2007
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
SOURCE: Shark Euro-Pro Sewing Machine
I had the same problem with my Shark Euro Pro 7133. My problem was in threading the upper thread. The manual does not quite explain so I had to figure this out the hard way.
In threading the upper thread . the thread first goes down from the spool througt a groove. When it comes up it must catch a silver lever that moves up and down before moving it down againPlease let me know whether this helps.
Posted on Jul 26, 2008
How to fix a thread correctly on a Toyota sewing machine model 5500
You don't state what is the problem with the thread so we are unable to provide helpful suggestions.
As a starting point, make sure to install a brand new needle that is compatible with the thread & fabric you are sewing.
All About Needles
Second, always raise the presser foot while threading the upper thread.
Make sure the thread path is correct (consult the owner's manual), insure that no thread guides are skipped or the thread is not wrapped around something it shouldn't be.
Set the upper tension at the midway point between low & high numbers to test stitch. Tension is correct when both upper & bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
Apr 12, 2016 | Toyota Sewing Machines
Instructions Toyota sewing machine 2700 EC 1 Series
Hi Guys, here is the link for manual
Toyota 2700 & 01/02 EC1 EC1b & other models,
http://www.supsew.com/KnowledgeBaseArtefacts/Documents/Toyota/Instructions%20Manual%20Toyota%20EC-1.pdf
Oct 09, 2012 | Toyota Sewing Machines
My needle wont sew on my husky star 207?
change the needle--make sure it's the right needle for the fabric
being sewed
rethread the machine top using every thread guide
check to make sure the bobbin is not over wound, make sure the
bobbin is not warped, & that the bobbin is inserted correctly into the
machine
make sure the thread has not come off the thread take up lever
it's also possible that the machine is out of time
Jul 14, 2012 | Husqvarna Huskystar 207 Sewing Machine
When I use my Singer model 1120 for sewing straight lines, the thread bunches up underneath. What is the problem?
Be sure that the machine has been cleaned and oiled. Check to be sure the machine is threaded correctly. Check to make sure the bobbin was wound properly.
Oct 31, 2011 | Singer 1120 Mechanical Sewing Machine
Everytime i try to sew anything my sewing machine gets the string all tangled up and just stops.. I just want to sew a straight line and idk how exactly to put the settings in a straight line. So that may...
Download a copy of your manual for free at www.brother-usa.com under support for home sewing. Follow the steps for threading because you do not have it threaded right. Save a copy to your computer and enlarge the diagrams for easy viewing.
Dec 28, 2010 | Brother XL-5130 Mechanical Sewing Machine
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
Model 2200 EC1 SERIES The top thread Bunches and tangles on the underside of the sewn material. I have checked that the upper thread tensioner is in good order. When I observe the thread in the shuttle...
try these suggestions
1.check to see if your needle is bent-place needle on flat surface & see if it rolls good
2.if needle make poping sound when going thru fabric it is blunt
3.check to make sure the bobbin is not warped
4.make sure there no loose thread or lint in bobbin area
5.make sure there are no burrs on bobbin or bobbin case
6.check to make the thread does not come off the thread take-up lever
Aug 23, 2010 | Toyota Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Sewing Machines Logo
225 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
