Question about Indesit W 123 Front Load Washer
Cylce goes on for hours and not washing the clothes, and they come out with little marks which looks like oil. very little water coming into machine. which a 1200 WIL1233
    Genius:
  • Indesit Master
  • 1,466 Answers
Could be Oil from drum bearing unit fault..Will be noisy too on spin...
Posted on Nov 16, 2009
We have a GE Profile Harmony. After the washing cylce is over, water keeps leaking onto the clothes. Any ideas?
you have a bad water valve. you can replace the valve and it will be fine. I will warn you that working on your machine can be complicated. after you look closely at the how, you may decide that a pro is the best way to go. here is a link if you decide to tackle it yourself.http://www.partselect.com/ModelFrames.aspx?ModelID=467904&ModelNum=WPGT9360E0PL&mfgModelNum=&ManufactureID=2&Selected=00117836i01&Position=2&mfg=GE&Type=&Mark=2
May 13, 2012 | GE WPGT9360EPL Top Load Washer
My clothes have rust marks on them
Most Washing machines have a coated washer basket in them-- But the coating on these baskets can get chipped, (From coins, or keys, etc. left in the clothes being washed..) Can you take a flashlight, and look and feel the inside of the basket, and look for such chips?-- Is the metal underneath showing thru?-- is it rusting?
If that is not the source-- How about the water coming into the machine?
Is the plumbing in the house old?-- and possibly a source of rust?
If all your piping is copper or plastic--
could it be the water itself?-- are you on Well water, or city water?
Tell us more about the rust marks themselves-- any unique pattern, or situation that make the marks come or go?
Mack B
Dec 28, 2010 | Westinghouse Washing Machines
Washing is coming out with black marks on the clothing. Probably due to grime in the pipes. How do I clean the system best?
Hi just read your posting.Is the black marks oil or lint?Has the machine been noisy on spin?If the marks are lint then try this !--Buy 2 pkt of Bicarb of soda. 2--Select high water fill.3--Select hot water fill. 4--Pour bicarb into empty machine.5---Push the start button. 6--Let it fill then wash for 5 to 10 mins. 7--Turn off the machine and do not let the water that is the machine drain.8--Now the machine sit overnight with the water that has bicarb in it .9-- In the morning put it throe a complete cycle and it should be free of lint and dirt.Please reply if you need further help or if the marks are oil.Looking forward to see how you got on.
Jun 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool duet continues to fill with water
does the waste pipe go into a trap under the sink if so it can syphone from the sike back in to the machine
if not one of the water valves is sticking change it your self or get an expert to change
Jun 29, 2009 | Washing Machines
Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Feb 02, 2009 | GE Energy Star WCVH6260F Front Load Washer
After washing cylce complete; 3-4 inches of water is left
it sounds as tho water is getting intyo machine after use. there are 2 possible causes.
either
inlet valve leaking. turn water off and see if this stops water accumulating. if it does, then you need to replace valve to cure.
or
if drain is plumbed into spigot on sink trap then every time you drain sink, some of the water goes down the drain hose.
to cure, take the drain hose up as high as possible in a swan neck
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Black oil or grease on clothes after washing
is you machine a top loader or front loader? if its a front loader the black marks could be from the boot. WIpe the boot with a good cleaner. and try not to over load machine. and if it a top loader your transmission is probably leaking oil back into clothes tub. You could have it rebuilt $$$ or better replace the machine.
May 22, 2008 | Washing Machines
LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Indesit W 123 Front Load Washer Logo
129 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
