Question about Graco Snugrider Infant CarSeat Stroller Frame
Vauxhall vectra back seat belt malfunctionback
Have a vectra hatchback the back middle seat belt wont pull out and tightens when the back seats are put down
    Problem Solver:
  • 14 Answers
Sounds like the recoil has gone or sliped out of the belt unit get a second hand one from a breakers yard becuse if you open up the belt unit you will be finding bits all around your garage for weeks,
Posted on Jan 14, 2010
How do i fix a jammed rear seat belt
You must remove the rear seat bottom and remove the bolt for the seat belt retractor, this will allow you to in jam the seat belt.
Dec 13, 2015 | Vauxhall Astra Cars & Trucks
Back seat belt wont lock
Check to be sure it is the right belt and latch combination.
I believe you have 3 seat belts in the rear. The latch for the two side ( door) belts is not the same as the one in the middle.
VERY often, one of the latches will fall down in between the seat rest and the back rest of the seat, often from dis-use.
This happens on all cars.
You should have 3 latches on short straps in the middle of the rear seat.
Be blessed.
Feb 02, 2013 | 1999 Subaru Legacy
Pt cruiser stuck middle seat belt
The problem:
The set belt stop has been lost so the seat belt retracts too far when the seat is laid flat. When laid flat the release mechanism lock as it should when not level. So the seat cannot be raised up as the belt is too tight and locked.
The Solution:
1) Push the two little clips to release and remove the headrests.
Pull the grey lever on the right of the seat base, lift seat base up and forward toward the front seat..
2) See two red capped leversat the back of the two seat hinges and lever them to the upward position, this releases the seat.
Rock the very heavy seat unit upwards and lift complete unit upwards.
3) Take it out of the car and turn 180% so that the back of the seat and base are in the upward position and the seat belt will pull out as it should
4) Replace the missing belt locking stop (I used a tie pin permanently fixed using super glue).
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption..
Aug 02, 2012 | Chrysler PT Cruiser Cars & Trucks
How to fix a 2001 vectra seat release
You can try to pull on the belt with the plastic trim piece removed the take a flat tipped screwdriver the release the arm or bar holding the belt in the lock position. Most of these have a spring on them. That spring can fall out. Or sometimes the bar or lock arm may be jammed and needs to be pried loose then lubricated to prevent this from repeating in the future.
Jun 04, 2012 | Holden Vectra Cars & Trucks
Car seat belt stuck
there is mechanical lock on every seatbelt activated when you push the breaks find lock and realse it by hand
May 08, 2010 | 2000 Ford Focus
2005 Saturn Vue with locked middle seat belt....
You'll need to take the housing cover off the seat belt, from there you should be able to access the tension switch on the seat belt. It sounds like it may be set too high...
Aug 21, 2009 | 2006 Saturn Vue
Rear middle seat belt wont retract
Sounds like a mechanicel problem in the belt box. Do you have a guarantee for that car?
Aug 17, 2009 | 1996 Toyota Corolla
Rear seat down and wont go back up; locked middle belt
middle seat belt shouldn't have anything to do with it. The seat locks down for stowage in the rear cargo area. you can pull the release handle on the back of the seat to release it back into the up position.
Jul 01, 2009 | 2006 Saturn Vue
My Vauxhall Vectra 1800 have just failed its MOT on rear seat belt 'fluffing'. No one ever sits in the rear of my car, and the same garage passed it last year. I have done nearly 500 miles this year. Are...
yes they can fail it but if u remove the rear seat and belt then it will pass advise NO REAR SEAT but they cant fail it 4 not being there as they cant acually test it! thanks jezza
Mar 03, 2009 | 2001 Mercury Grand Marquis
Graco Snugrider Infant CarSeat Stroller Frame Logo
783 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
