Question about Hamilton Beach BrewStation 47214 Coffee Maker
The small release on bottom of brewstation keeps moving out of place
Hamilton Beach is sending out a new coffee tank, no charge!
Posted on Nov 18, 2009
Hamilton beach brewstation leaking
Sorry but if this company is like the BUNN corp there are not parts available to repair. they want to sell new only.
Nov 17, 2015 | Hamilton Beach BrewStation Deluxe 47474...
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
As coffee exits the BrewStation, it comes out in a weak flow at first, then it starts to run down the back missing the cup. Coffee runs down to the base. Must tilt the entire assembly to get some coffee....
The filter screen at the release valve is clogged with scaled coffee. You need twist and pop it out and clean with a steel wire brush and then pop it back in place.
Oct 09, 2010 | Hamilton Beach BrewStation 47214 Coffee...
CODE 5020....Release scanner lock switch....What is this?
It's a physical "lock" to prevent the scanning-head from moving while the whole unit is being moved.
Compare it to using a seat-belt while driving your car -- it keeps you in the proper & safe place while your car is moving.
Look carefully at the FRONT and/or BOTTOM of the scanner for the "lock/unlock" switch.
May 17, 2010 | Office Equipment & Supplies
Reassembly instructions
That little screen that lies at the bottom of the bucket needs to be snapped out and the washer replaced. You have to unscrew the bottom, carefully remove the spring loaded lever, ( don't loose the spring) After fishing the lost rubber washer out of the hole, I used a screw driver or other similar item to pop the screen out. ( use care not to poke a hole in screen.) Next replace lever and spring and push the Star ended piece through the bottom and THEN fasten the washer. Replace all excess pieces and it should be fixed provided the washer isn't badly worn. This is the only way I know how to fix it after countless different web pages and searches.
Apr 08, 2010 | Hamilton Beach BrewStation 47665
My hamilton beach brewstation is leaking.
There is a spring between the lever and the o-ring. It may have popped out when you cleaned the pot. That has happened to me before. The spring is necessary to hold the seal down until the lever is pushed.
Mar 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Thoroughtly clean the lower basket. Probably has some small pieces blocking the flow under the filter causing it to back up. Repetatively push the button the pot hits on the bottom of the filter unit to losen any small pieces lodged there..
Sep 18, 2008 | Hamilton Beach BrewStation 47214 Coffee...
I found this site that calls it a "permanent dispencing filter" but the small print says that it is the small domed filter that sits on the bottom of the tank so I sounds like the same as the filter screen. FYI, there is a pricing conflict when you click on the part. The part link shows that it's $4.99 but when you select the part or try to order it, it comes up as $5.99. Here's the link http://abtecparts.com/hamilton_beach_brew_station_filters.htm
I will probably still call HB tomorrow and see what the want for it before I buy.
Jun 01, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Parts for Hamilton Beach BrewStation® 12 Cup Coffeemaker With Timer
http://forumappliances.com/images/Hamilton%20Beach/Hamilton%20Beach%20Parts/Hamilton%20Beach%20P-990021600.jpg
It's called a tank, not a pot. $9 CDN. Haven't been able to find in US yet. This is very hard to belive considering they make so many small appliances I think HB is not making parts available intentially to get consuners to buy again. Not sure this is smart.
Feb 12, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
909 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
