Question about Cell Phones
I have a flashed Motorola Q and its flashed for Cricket service, but my problem is getting it out of roaming. So i took it to a Cricket store and they told me that they would be able to give it service but I needed to unlock the phone. All I need is the unlck code, would you be able to help me?
I want to flash a metropcs phone to cricket
Flash or Flashing--Technically, flashing refers to the overwriting or re-writing of the phone's firmware. There are many phones which can be flashed to cricket with all features working. On most CDMA phones, programming the phone can be done "over the air" by dialing a special code, usually *228 or some variation. Colloquially speaking, flashing can also loosely mean making a phone from one carrier work on another carrier. The easy way to tell the difference is that if your phone does NOT take a SIM card, then it is probably CDMA.
To flash a phone to cricket you will be overwriting th phones firmware. The firmware is software in the phone that doesn't change when you turn it off, and it cannot be deleted unless it is overwritten, hence flashed. It requires specific files called prl files.PRL or PRL File--Short for Preferred Roaming List--A small text file containing instructions for how a phone connects to a specific network's radio towers It is usually loaded by connecting the phone to a computer to overwrite its data. There are a few tools used such as a pst PST--Short for Phone Service Tool or Tools--Special software used by phone manufacturers to program their phones. And also a monster file - -"Monster File"/"Monster Pack", ROM, or "Kitchen"--System software that is needed to flash a phone.
In almost all case you will need to access the phones service programming menu- - -Service Programming Menu--A special menu typically hidden from the primary User Interface that allows for "deep programming" of a phone.You will also need access to msl and spc codes specific to the device you are flashing.MSL/SPC--Special six-digit codes needed to access service programming features on the phone. Access to the service programming menu can be disabled in a phone's firmware.
Depending on your phone, it may require extra steps to unlock or get WAP and MMS working. That is why you need the msl/spc codes to allow deep programming to unlock these features. Not all phones will be capable to access wap or send and receive mms.
Ringtones generally have to be prepaid using a flex bucket. It is best to download ringtones before you flash your phone to cricket since they have a limited selection of ringtones and wallpapers.There are cases were flashed phones will not be able to download ringtones directly from cricket.
The details outlined above will not only work with cricket but you can also flash phones to metro pcs using the information provided above. It is best to do all your research before purchasing your phone to ensure that the cell phone you are interested in can be flashed to cricket or metro PCs
Feb 21, 2012 | Motorola SLVR Cell Phones
Moto q
I believe the Moto Q can support this so the basic flash you received only hacks the SPC, changes it to null value and writes the PRL (preferred roaming list) for Cricket and it's partner carrier's towers. Then, assuming it has not been reported lost or stolen, they will add your ESN (electronic serial number) or IMEI (international mobile equipment ID) so you can make and recieve calls. This does not enable picture messaging or internet. This is a separate procedure using computer software and there are several things which need to be changed in the firmware like your MID (mobile identification number) web addresses, protocols, and passwords for Cricket mobile service. You will need to take it to the person who flashed your Verizon and ask for the full flash so you can get the internet. I hope this helps. If you already paid for the full flash ask them to redo it and test it before you leave the store.
Jul 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Help to flash phone
  • www.unlocktotalk.com
  • Check out this website they are knowledable and have pretty good prices.
  • If you don;t know how to flash a cell phone, don;t attempt it unless you have hours to learn.
  • Good Luck
Apr 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Samsung u340 won't show roaming or not
you may wont to contact cricket and get verification on your service area........the roaming triangle should only apply to the device main screen when the towers being used have a roaming contract with the provider. you may very well be roaming but not from your device.....you may be roaming in the cellular network though.....contact cricket from another device for troubleshooting options at (866) 274-2538
GOOD LUCK !!!!!!!!
Apr 11, 2009 | Samsung SCH-u340 Cellular Phone
How to use the unlock code
I think you have to take it to crick it so that you can have it flashed, where im at the cricket stores will do it for like 25 bucks..
or once again call your service provider.
Feb 04, 2009 | Motorola Mobility C118 Cellular Phone
Flashed motorola q not working with cricket internet
have you added the data package to your plan?
if you call customer care they with provide you with the wap/tcp settings. they dont care what phone you have... as long as your paying a bill thye are happy.
Jan 27, 2009 | Motorola Mobility Moto Q
I have a MOTOROLA MOTO Q PDA flashed to CRICKET - internet probs.
my cellphone is already flashed and in use, but i cant use the internet i i ready try everything what can i do??
Nov 17, 2008 | Motorola Mobility Moto Q
LG Fusic Flashed to Cricket
if its a flahed phone no gurantee the pics web and roaming will work
Apr 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
61 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
