Tv will work fine for 10 minutes then picture starts to break up and then unit shuts down
  • 4,234 Answers
The behavior implies that either a connection is effected by the heat of running or a component is failing under those conditions. It would be helpful to know the following:
1) Make and model of the unit in question here.
2) A description of what you mean by "starts to break up".
The shutdown is occurring because of internal protection circuits that kick in when a problem is detected. This is to prevent further damage. We should be able to provide a more detailed explanation of the problem and possible solutions once the info is posted.
Thanks,
Dan
Posted on Nov 16, 2009
I have a TN55x81. the picture will just stop working (goes black). I will shut it off for about 5 minutes and then it will work fine. Some times for 2-3 days and other times just 10-15 minutes. Any ideas??
Intermittent problems on this type of TV are often because of cracked solder joints on the circuit board. They can be hard to see. When the TV gets warm, parts on the board expand and move by tiny amounts, sometimes with the right amount of expansion or vibration from the speakers, the broken solder joint looses connection and the unit shuts down. When things cool-off, the contact can be made again all by itself and everything fine until it happens again. Given the random nature of your problem, this is a suspected problem. Often it is the solder around the lead of a large component which is mounted to a heatsink.
Jan 22, 2011 | Toshiba TN55X81 55" Rear Projection...
I have a 7 year old toro timecutter zero turning radius 16/42" mower. It starts and mows fine but after about 10 minutes of mowing it loses power and dies abruptly. After sitting for 10 or more minutes it...
could be a ignition unit (s)breaking down when it getts hot ?
could be a tank breather not working or a restriction in flow of fuel
could be a valve not opening fully or closing fully ie tight valve
fit in line ignition tester and run unit and see if spark disapears when unit gets hot if so ignition prob if not its other problems
worth a look
cheers
Jun 30, 2010 | Garden
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
Pd46c10 daewoo plasma
I have a DAEWOO PD46C10 recently it would come on display a beautiful picture play for 10 minutes and the screen would go black.After several minutes reset turn it on and the process starts again.Whats the problem and where can I get it repaired???????????
Nov 25, 2007 | Televison & Video
Losing picture
Six blinks error code could be the Thermal Fuse part# 1-910-006-44
Sep 28, 2007 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
