Question about Dryers
The dryer still works properly but squeals terribly after about 10mins use,I have gained access to the top of the drum and the drive belt doesn't appear to be slipping so could it be a bearing??
    Scholar:
  • 86 Answers
Check the small plastic sheets in the front of the drum. If they are worn down, that's your problem but there are two wheel bearings on the bottom of the dryer drum, depending on your model. Hope this helps, Good Luck...
Posted on Nov 17, 2009
How do I stop my Whirlpool Imperial Series Dryer from squealing when it starts
Mike:
You should be able to open the top of the dryer by gently prying up on the front of the dryer at the point where the top and body of the dryer meet (don't chip the paint). There should be a metal clip, pointing down, at each corner that snaps into two holes in the top of the dryer body. The top of the dryer will pivot up and back. You can see the drive belt and drum. The drive motor will be below and to one side of the drum. You can clean the path where the belt runs around the drum by turning the drum by hand, and check the belt for cracks, brittleness or a shiny appearance. A cracked, brittle or stretched belt will require replacement. I removed the belt from my dryer, and it was not cracked or stretched, so I bought a product called rubber drive restorer (from an electronics shop) to recondition the belt and reinstalled it.
Jun 16, 2015 | Whirlpool Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Bosch dryer lights up when turn on nut drum does not spin
The drum spins around by the belt surrounding the parimeter of the drum. A tensioner is also part of this system. You may have a broken belt although the belt usually squeals before breaking so I think the tensioner is at fault. The top would have to be removed then the front panel next to gain access to these items
Mar 31, 2010 | Bosch Nexxt 500 Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
Im trying to replace the belt on an indesit condenser dryer model number is70c the drum has stopped working and this is the option im looking at
To gain access to the drum and belt, remove top cover and right hand side panel looking from the front.There you will see the main working parts.
Feb 01, 2010 | Hotpoint Dryers
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Replace bearing and bushing g.e. profile dryer
Yes, but you will have to swing the top open, remove the dryer front, and pull the drum forward about 4 inches (leaving belt on drum) to gain access to the bushing. Normally that is all you have to replace, but also check for wear on the front drum slides at the same time.
Jan 21, 2009 | GE Dryers
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Drive belt replacement on a Miele T230C tumble dryer
You must route the belt either in front of or slip it behind the drum to get it down to the drive wheel. You should remove the front panel to be able to do this the best.
Jul 05, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
