Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
It runs for about 15 minutes, then shuts off. Tracks, fan blade, and filter bag are clean.
    President:
  • Smart Master
  • 1,378 Answers
We can handle servicing the unit or selling you parts to try yourself. Please use the Dolphin form along the bottom of our web page at www.arrowpools.net and be sure to include the serial number from inside the unit to ensure correct parts are identified.
Posted on Nov 19, 2009
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Vacuum runs for 5 minutes ,then shuts down. Will restart after 15 minutes, then does same thing.
sounds like a built in feature. It is overheating, bad wire or circuit possible
Jan 01, 2015 | Vacuums
Goodman a42 15
A high temperature operating thermostat will cause a problem like this. Limit switches need to be reset, but operating stats don't. Be sure your blower fans filter is clean and the ducting and path up through the furnace is clear. Stay in touch. Roger
Dec 16, 2013 | Heating & Cooling
Mach 4.7 runs for 2.5 minutes and shuts off
Did you use it to vacuum up fine materials like powder? If you cleaned the filters, but they are original to the machine, replace them. Try changing the bag to a fresh one as well. Beyond that, check how freely the brush turns. If it doesn't turn freely that can but excess load on the motor, if its covered in threads, remove those.
Aug 01, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Shuts off after 15 mins
its hitting the high limit temperature switch...
is the heater clean inside? clean any dirt or dust off the fan blades and vent grills.
Is the fan turning and running at proper speed?
Jan 07, 2011 | Patton PUH680-U Utility Heater
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
Shuts off after a minute or so and comes back on and shuts down in 20 seconds
Sounds like it is over heating do to a dirty filter. Or there is something blocking the air flow in the vacuum.
Jim
Dec 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
LG 1200 btu ac unit works fine for 20 minutes then shuts off compressor and continues to run fan only. Shutting it off for 15 minutes and then works fine again for 20 minutes.
You do not say if it is outdoor or indoor fan which operates. However I presume all your filters are clean and the drainpipes are clear. The only other thing you could suspect is the thermostat or air flow sensor.
Jun 25, 2009 | LG Heating & Cooling
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
309 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
