Question about Bushnell NorthStar 78-8831 (525 x 76mm) Telescope
Cannot see anything.
Just got a 78-8831 and set it up according to instructions.  After inserting lens into eyepiece, I can't see anything at all.  Dont worry, I've removed the front cap from the the main telescope.
Something leads to believe I'm either missing something real fundamental or my telescope is broken.  Please help
I cannot see anything either. I've spoken with several people where it was bought and they assure me that everything is set up corretly. I cannot find and telephone number to call someone for assistance.
  • rnska2 Feb 16, 2008
    I can now see things through it but they are upside down. What can I do to fix this
  • Bushnell Master
  • 19,396 Answers
In addition.... you can download the complete manual immediately here :
http://www.astronomics.com/main/documents/bushnell/78-8890_northstar.pdf
cheers
Posted on Feb 16, 2008
  • 796 Answers
Hello sir
  • 1 more comment
  • isaac johny
    isaac johny Feb 16, 2008
    If you dont have any experience with telescopes, I suggest trying it
    first in daytime, since daytime objects are much better for getting
    experience. Also, start with the lowest power eyepiece,
    the one with the largest lens. Start by looking towards something
    pretty big, like a car or a house, and it needs to be some distance
    away to even have a chance to get a focus. If your target is closer
    than about 1/4 mile, you should add the right angle eyepiece attachment
    to allow you to focus in on closer objects.
    When you are finally
    set up with the low power eyepiece, and have a good big target in the
    daytime, start looking thru the telescope while turning the knob thru
    the entire range. At some point of knob turning, you should see some
    image appear in the eyepiece..Turn the knob slowly to focus it clearly.
    And
    this is for the shaky tripod. If you can hang a book under the middle
    of the tripod, the added weight will help stabilize the telescope, and
    you should be able to see a little better, without so much motion at
    the slightest touch.
    After you look at the first car or house,
    you can see how careful you have to be to use the telescope,
    and you can start to look at other objects. When you move to the higher
    power eyepieces, it will be even more critical in getting it both
    aimed and focused. If its off by just a few degrees, you wont see what
    you are looking for.
    When you start nightime viewing, start with
    the largest object in the sky, the moon. Its the same process as
    daytime, except the eyepiece mechanism will have to be adjusted a
    little closer to the main body of the telescope.
    Viewing planets
    and stars will be the ultimate test. Stars and planets are harder to
    see, since they are small, and hard to see unless they are in focus.
    When you can see those views, you have passed the telescope test. Its a
    matter of careful aim, and having the telescope focus set close to the
    point where you can see objects that are VERY FAR AWAY. If you are able
    to focus on the moon, you will be fairly close to being able to focus
    on the planets. The hardest part is actually getting the planet in the
    view of the telescope, in other words, aiming it.
    The last item
    that can really mess up the view is a fogged up lens. Usually this
    happens in the summer when the scope has been in the air-conditioned
    room, and then it fogs up when taken outside. The solution for this is
    to let the telescope sit outside for 20 minutes, so the fogged lenses
    can clear. By the way, the same fogging may happen when you bring the
    telescope inside during the winter.
    I hope this helps you
    eventually get a clear view of some amazing views in the sky. Your
    final exam is to take a look at the moon, the rings of Saturn, and the
    moons of Jupiter, some time in the near future. Have Fun!
  • isaac johny
    this is taken from fixya site only...if it was helpful plz reply
  • isaac johny
    As we all learned in grade school, telescopes produce an upside down
    image - it's okay for astronomical use since upside down doesn't
    matter. If you want an image like you'd see in a pair of binoculars,
    get an image erector from a telescope accessory store to add to your
    eyepiece.
    Sergeant:
    Champion:
  • 347 Answers
Hi Rnska
If you dont have the manual and you wish to take a look at it, you can get it here. You will have to register (at the right) you can fill it with fake info if you want, then you will be able to download it.
Posted on Jan 09, 2008
  • Santiago Vallejo
    Santiago Vallejo Jan 09, 2008
    you can also try it in day time. Aim at anything during the day and if you see a blurry image, but not just black, that means you were not aiming at nothing last time you tried it, or maybe there were many clouds in the sky.
    Scholar:
  • 152 Answers
Do you at least can see some light trough the part where you put the eye? if you cant see a light, then setup is wrong and there is something blocking your view...
otherwise.. it needs to be refocused... maybe you arent pointing it to your target correctly...
try pointing it to the moon (since its big and hard to miss) then, if you get some light (no matter if its blurry or not) start focusing and maybe cleaning the lens...
good luck with that.. hope that helps
    Guru:
  • 1,894 Answers
Do you see only black image when you look trough it?
  • dewan nafees ahmed Jan 09, 2008
    This would be difficult to answer without being there to check it out
    myself. however be aware that if it is a reflector scope the angled
    mirror on the inside may have a protective cover over it, or it may be
    angled wrong, if you had to assemble consult the directions again. Also
    the finder scope may not be in line with the main . try removing the
    view lens and moving in little circles tword the moon you may notice
    lite on the inner wall of the scope. if its a refracter the its
    defiantly miss alignment between finder and main try a day lite target
    and the adjust the finder and main in both instances before it gets
    dark, hope that helps . Also you could try finding a lit in your
    neigbor hood like a street lamp and with the lowest mag lens try to
    align your finder too the main
    You say the lens cover is off, but is it _completely_ off? Many
    telescopes come with a two-part lens cover. If you've only removed the
    middle part, the light will be blocked from reaching the primary mirror
    by the secondary mirror. When the lens cover is completely removed, the
    hole in the end of the tube should be as large as the tube itself.
    Another possibility is that the secondary mirror is rotated out of
    position. If you look in the focuser without an eyepiece in place, you
    should see the secondary mirror. On that you should see a reflection of
    the primary mirror, and in the centre of that, a reflection of the
    secondary mirror, and within that a reflection of your eye. All should
    be concentric. If not, first adjust the secondary mirror, so that the
    reflection of the primary mirror is centred in it, then adjust the
    primary mirror so that the secondary is centred in it. This is called
    collimation. Check the source for more details and illustrations.
    source is from yahoo answers.
I have a Bushnell Voyager telescope and can't see anything thru it at night!
Did you set it up according to the provided instructions?
Do you have a low power eyepiece inserted at the viewing end?
Have you aimed the telescope at the moon as a basic test of
visibility?
If your telescope is not properly aimed at the target (a star or a planet, or other object in the night sky) then you will see nothing.
If the power of your eyepiece is too large and your telescope aim is
not "dead on", then you will see nothing.
Have you tried using the scope in the daytime? Do you see anything?
Aim at a specific object, or section of an object, like the top of a lamp-post about a block or two away, and see if you can focus on
it the eyepiece.
You really need someone at your side who has experience in using
astronomical telescopes. That would be the quickest way to solve
any problems you have.
Unless your question is very specific, and unless you provide as
much detail as possible about your problem, it will be difficult for
anyone to provide you with speecific answers that will help you
solve your problem.
joy,
walt
May 06, 2014 | Bushnell 789961 Voyager Sky Tour 700mm X...
When I use a Barlow lens do I insert it before focusing on an object through the eyepiece or do I insert the lens after I've focused on an object (eg: Jupiter)
You will have to refocus after inserting the barlow. The barlow will change the focal point of the eyepiece
Apr 06, 2013 | Optics
I was given a barska 40070 i was assembling it then i came across the barlow lens i tried putting it on my telescope i did but then i went outside i had aligned everything prior to it I looke into the...
A barlow doubles the magnification of the eyepiece and halves the field of view so it it very hard to center an object. Use the lowest power eyepiece (highest number) first. Center the object in the eyepiece, then you can insert the barlow between the scope and the eyepiece. You will be surprised how far off from center you are.
Dec 27, 2012 | Barska 40070 Starwatcher Compact Refractor...
What is the different parts on a microscopes
Therre are the three sections normally , the first the eyepiece which the one to set the focus according to the lens choice .The seccond is the main tube containing the set of lens for magnification and the third consistts of normally three settings of lens with different focal lengths. You can use the coarse settings , the the fine and the micro, use the eye piece to set.
Sep 01, 2010 | C And A Scientific My First Lab Digital...
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
I dont know how to use my barlow lens
I use a barlow lens quite a bit with my telescope. It is usually inserted before the diagonal if you use one or before the eyepiece if you don't. The barlow lens for your telescope will double the power of the eyepiece used.
However, despite what the manufacturer claims for your telescope things will look quite poorly if you try to view at 180 power. Generally you'll get the best images by using 50x for each inch of your objective lens. For example, your telescope has a 50mm lens. That's roughly 2 inches. 2 inches times 50x gives you a maximum useful power of 100x. Depending on the viewing conditions you may be able to exceed this or not even reach it. Things will look blurry and dim when you try to use too much power.
Your power or magnification is calculated by dividing your telescope focal length which is 360 mm by the eyepiece focal length. You have two eyepieces with focal lengths of 4mm and 20mm. If we divide 360mm by 20mm we get 18 power. If you add a barlow to that you get 36 power. Dividing 360mm by 4mm (no barlow) we get 90 power. That would be your maximum useful power.
Therefore, you should be able to used the 20mm eyepiece with or without the barlow but the 4mm should only be used without the barlow.
I hope all of the math wasn't confusing.
-jodair
Feb 12, 2009 | Edu-Science (10166) Telescope
Bushnell 700x76
Jan 29, 2008 | Bushnell 3" Reflector Telescope w/Talking...
What lens do i insert into scope to view the moon
The moon is big so use the 25mm. The Barlow will have a multiplication marking on it 2x 3x etc. A 2x Barlow lens will effectively double the power of the eyepiece you are using. Do not use the erecting eyepiece for anything other than land viewing. Erecting eyepieces generally reduce the amount of light reaching your eye and thus reduce brightness of the faint objects in the sky.
So basically just place the 25 mm lens in the focuser and point the scope at the moon and you will be amazed at what you can see and how bright it is.
Dec 30, 2007 | Tasco 350x50mm Refractor Novice Telescopes
78-8831
If you dont have any experience with telescopes, I suggest trying it first in daytime, since daytime objects are much better for getting experience. Also, start with the lowest power eyepiece, the one with the largest lens. Start by looking towards something pretty big, like a car or a house, and it needs to be some distance away to even have a chance to get a focus. If your target is closer than about 1/4 mile, you should add the right angle eyepiece attachment to allow you to focus in on closer objects.
When you are finally set up with the low power eyepiece, and have a good big target in the daytime, start looking thru the telescope while turning the knob thru the entire range. At some point of knob turning, you should see some image appear in the eyepiece..Turn the knob slowly to focus it clearly.
And this is for the shaky tripod. If you can hang a book under the middle of the tripod, the added weight will help stabilize the telescope, and you should be able to see a little better, without so much motion at the slightest touch.
After you look at the first car or house, you can see how careful you have to be to use the telescope, and you can start to look at other objects. When you move to the higher power eyepieces, it will be even more critical in getting it both aimed and focused. If its off by just a few degrees, you wont see what you are looking for.
When you start nightime viewing, start with the largest object in the sky, the moon. Its the same process as daytime, except the eyepiece mechanism will have to be adjusted a little closer to the main body of the telescope.
Viewing planets and stars will be the ultimate test. Stars and planets are harder to see, since they are small, and hard to see unless they are in focus. When you can see those views, you have passed the telescope test. Its a matter of careful aim, and having the telescope focus set close to the point where you can see objects that are VERY FAR AWAY. If you are able to focus on the moon, you will be fairly close to being able to focus on the planets. The hardest part is actually getting the planet in the view of the telescope, in other words, aiming it.
The last item that can really mess up the view is a fogged up lens. Usually this happens in the summer when the scope has been in the air-conditioned room, and then it fogs up when taken outside. The solution for this is to let the telescope sit outside for 20 minutes, so the fogged lenses can clear. By the way, the same fogging may happen when you bring the telescope inside during the winter.
I hope this helps you eventually get a clear view of some amazing views in the sky. Your final exam is to take a look at the moon, the rings of Saturn, and the moons of Jupiter, some time in the near future. Have Fun!
Dec 26, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Start by adjusting the focus draw tube all the way in, then back a little bit. In the day time indoors, remove the lens from the draw tube. Look into to the draw tube. You should be able to see your eye centered in the mirror. If you cannot see your eye at all, either the primary is tipped drastically or the secondary mirror is way out of adjustment. In that event I would return this scope to where you got it.
Oct 26, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Bushnell NorthStar 78-8831 (525 x 76mm) Telescope Logo
264 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
