Question about HP PhotoSmart 7150 InkJet Printer
Blinking light one light keeps bliking and will not print
  • mark0308 Dec 05, 2008
    It is the light that looks like a raindrop. We checked the ink and it's not empty or even close to it. It just won't print.
  • hotice7wx May 20, 2009
    I also have the same problem. The light in between the X button and the paper feed button is blinking. It is yellow in color and it looks like a raindrop. I replaced the ink cartridge and it still won't work. Please help. Thanks!
  • 4,402 Answers
Which light?
Posted on Jan 09, 2008
Error bliking green light an not printing
If only the power green light is blinking, you could try a printer reset that may correct the problem.
1. With the printer on, disconnect the plug from the electrical outlet.
2. Wait at least 3 minutes
3. Plug back into the outlet.
Dec 27, 2013 | HP Deskjet 2050 All-in-One Printer
Hp photosmart c3150 keeps color light and check cartridge light keeps bliking after replacing with a new one.
It sounds like you ink cartridge is electrically bad; you can run the diagnostic 'tap 41' test to confirm. The HP 31xx printer 'access procedure' will be very similar to this HP Fxxx series access procedure:
Good luck:
Feb 19, 2013 | HP Photosmart C3150 Printer
Removed battery for 2002 mustang, put battery back in and now theft lite keeps blinking but car starts Ok. Light keeps on bliking when car is running
You may need to reset the codes in the body computer, the loss of power will be the stored code or just drive the car but it will take a while for the computer to clear itself, this could take a week or two of driving, or again have it scanned and see what the codes are, i think it will be acode with antitheft power loss. hope this is helpful. good luck.
Mar 19, 2011 | 2002 Ford Mustang
Power light bliking
common on these models is open fuses and convergance. the blinks give a code to the issue. need to know the blinks , count the blinks please.
Jul 08, 2010 | Toshiba 55H70 55" Rear Projection...
All leds are blinking continously in Epson stylus cx 5500 printe
turn on/off, unplug, plug in2_bing.gif, should reset configs.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
If I understand corectly the machine need to program the coffee doses again, so place the filter hoder in head and a cup under press the first button and keep it press up to the point of water dose you want, then do the same with other buttons, finally press the stop button then the bliking will go away. If not a wire conector behing the buttons is removed or loose.
Jan 04, 2010 | Astoria Divina SAE-1 Espresso Machine
Carrier CR5BXA030000AAAA blinking red light
if you remove the door you see it blinking through there is usually a led diagnostic code list. before removing panel count the long and the short blinks and write the amounts down as you may resett the code by removing the door.
Nov 23, 2008 | Carrier 38BRC048 Air Conditioner
Hp 2460 printer bliking lights
I found that turning the printer off, re-seating the print cartridges resolved this issue for me. Good luck.
Sep 22, 2008 | HP Deskjet 2460 InkJet Printer
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
HP PhotoSmart 7150 InkJet Printer Logo
285 people viewed this question
Ben Johnson
