Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
When copy, print scan a blank paper comes out...why? Replace new ink cartridges and tryied to callabrate...no success....at one time a Kodak services #F555951, and error code 3607 registered.
  • 262 Answers
Have you done the media sensor calibration? You can do this by press menu button on yoour printer then scroll down look for media sensor calibration., The purpose of media calibration is to detect the paper that you are using to your printer., MOst of the time do ing the calibration will solve issue., Now if you still encounter same problem ther might be a problem on the printer or on the pritnhead., You need to call kodak 1 800 421 6699, I think the printhead is free of charged you may request for printhead replacement
Posted on Nov 16, 2009
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Kodak espc310 prints blank pages, replaced cartridges, printhead. Seems like the ink is going somewhere but not on the paper. Cartridges are already low.
Take it outside and run over it several times, pack the trash in a box with Kodak as the sender and receiver. drop it off at any PO and let them dispose of their junk.
Jul 19, 2012 | Kodak ESP C310 AllInOne InkJet Printer
Ive a kodak printer esp 7250 i have used it a couple times to print off my photos and its been fine,i got the printer out today and put new ink in ready to photo copy and it is not printing for some reason...
How long was the printer stored before you took it out to use it? You can't store a printer with or without ink cartridges in it. When a printer sits, the ink that is in the print heads settles and dries. Once that happens, the print heads are pretty much ruined. You can buy new print heads, but its usually cheaper to buy another printer instead. The reason it is not printing is probably because the print heads are plugged.
May 12, 2011 | Kodak Office Equipment & Supplies
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Red on print is coming out pink
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
Blank paper comes out
Please clean the print head for 3 to 6 times and after each cleaning print a nozzle pattern to verify if the cleaning is successful or not. After 3 to 6 cleanings and issue still present, reinstall ink cartridge. By doing all those steps and issue still present - the print head is clogged badly by dried inks or contaminants. If your printer is under warranty - I suggest call your printer's manufacturer and ask for replacement if not decide whether sending it to service center is cost effective or buying new printers.
Oct 02, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Not printing
Contact Kodak! I had similar problem after a paper jam. I phoned three days ago and this morning, a new printhead arrived along with two new cartridges. Have installed the printhead and printer is printing beautifully! Thank you Kodak! Great customer service!
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
263 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
