Question about Fujitsu Cameras
Zoom error I have a fuji A610 camera that has developed a "zoom error". The lens comes half way out and then starts shuddering. What is the "telephone trick" that other users seem to quote? Victor Marcinkiewicz
    Scholar:
  • 54 Answers
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Posted on Nov 16, 2009
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
I have got a zoom error on my fuji Finepix V10. When you turn the camera on the zoom starts to come out and then quickly retracts. How can I fix it?
Sounds like the timing for the sensors on the lens are out and will need to be reset.
lens unit will need to be removed and reset
Jan 02, 2010 | Fuji FinePix V10 Digital Camera
Canon Powershot a610 dropped, lens stuck half way, won't move, gives E18 whenever one puts it in the mode to take a picture, no view through lens. Is the camera toast?
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Nov 19, 2009 | Canon PowerShot A610 Digital Camera
What is Old Telephone Repair" trick
i need to know to!!!!!!!!! everyone is talking about how it fixed their camera, but i dont know what it is or how to use it! so the answer would be helpful, thanks!
Oct 05, 2009 | Fuji FinePix S304 Digital Camera
Fuji fine pix z1 error
I had the same problem and finally had the time to look at it. I was reading some other posts, when I read try the telephone trick. Leave the camera closed and kinda slam it on a hard surface. I slid the shutter open and focused and it took a pic with no problem!!!
Mar 21, 2008 | Fuji FinePix Z1 Digital Camera
Fujifilm A610
Try this solution: http://www.fixya.com/support/t143152-fuji_zoom_error_message
Jul 09, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Zoom error
No solution repair probably as expensive a replacement Contact Fuji the do a swap out at a discount service
Jun 23, 2007 | Fuji FinePix A360 Digital Camera
Fuji Zoom Error Message
Ronald, There is no easy fix, you?ll have either disassemble and get dirty, or take to an authorized repair person. This zoom error problem is usually caused due to dirt or dust in the zoom mechanism. If you think you can handle disassembling the camera then grab a set of gentile screwdrivers and follow these instructions: You will have to remove a few circuit boards in order to get to the zoom mechanism.
Apr 14, 2007 | Fuji FinePix S304 Digital Camera
Digi camare
The lens on your camera has become stuck due to being dropped, contamination such as sand, or a malfunction within the lens. If gently manipulating the lens itself does not free it then you will need to get it professionally repaired or replace the camera. David Millier Advance Camera Repair
Feb 07, 2007 | Fuji FinePix F401 Digital Camera
Cameras Logo
138 people viewed this question
Top Fujitsu Cameras Experts
Jerry Greenberg
Jerry Greenberg
Robin Hill
Robin Hill
Are you a Fujitsu Camera Expert? Answer questions, earn points and help others
