Question about Frigidaire ATF6000ES Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
    Scholar:
  • 62 Answers
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Posted on Nov 16, 2009
Mold spots on the inside of the rubber seal of the washer... how do i clean remove it/
two ways to remove the mold one you can either get some vinegar and water or bleach and water and sit with a bucket and a spong and scrub away on the mold areas or you can goto your local home depot and look for a product they sell called AFFRESH which is a product that not only cleans a front load washer it also prevents this mold occurance in the future you may need to use more then one tablet in order to clean you unit if you have never used AFFRESH before if you have any further questions message me back Thanks again Rick
Feb 13, 2011 | GE WSXH208A Front Load Washer
How do I get rid of musty smell from my Frigidaire front load washer?
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump.
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer and the rubber seal if full of mold. How can I get rid of it?
Oct 23, 2010 | Frigidaire ATF6000ES Front Load Washer
RUBBER LINER COLLECTING MOLD
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washer bucket has developed a black mold & smells.can I fix?
first you have to wash the mold away the next solution is to go to home depot and pick up a product called affresh it cleans out the inside of your washer this is a once every 1-3 months product that will also prolong the life of your washer and all front loaders ive also found that this works great in top loaders as well
Apr 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
The rubber hose around the inside door get dirty
wipe it down with 1/3 to one gallon of water and leave the door open when not in use.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
Clean with bleach solution and a Mr Clean Magic eraser.
leave the door open to dry out the machine from now on.
Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Hard, unidentifiable substance in washer
with almost all front load washers you have to remember to run clean cycles due to moisture in unit and door constantly closed they get mold and mildew along with debris from washing it can leave very strange looking deposits on the front rubber area because it collects these things.Suggest running unit with bleach and no clothes several times to get rid of foreign matter inside and leave door open after to dry interior out overnite and one more bleach cycle in morning and should be good to go after.Refer to manual from this point how often to running clean cycle.
Mar 25, 2009 | Kenmore 42822 Front Load Washer
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
542 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
