Question about Roper RAB2121KW Top Load Washer
Roper washing machine
The lid switch has gone out and I can replace it myself but I need to know what all i have to take off to get to it?
    President:
  • 1,314 Answers
It depends on your model but either way there are two screws in the front or back of your control panel back them out far as you can pull the control panel slightly forward and tilt it back then you will see two gold clips on the washer body pay attention how they go in there pop them out with a screw driver tilt the washer forward have someone hold it should be able to look underneath and get to the switch
Posted on Jan 09, 2008
How much will a lid switch cost for a roper washer serial # sm828087
If it were me, I'd first go to "Sears parts" and find the model number and part number of the part you need on their free diagram.
Then, I'd got to e-bay and type in that part number and see what that part would cost. I have often done this myself.
Be blessed.
Apr 21, 2013 | Roper Washing Machines
My roper washing machine will not empy out or spin. It agitates alright but stops when it comes to emptying the water and going into the spin cycle.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Replace the lid switch with this part.
Dec 27, 2010 | Roper RAS8445KQ Top Load Washer
My roper washing machine stops working but will restart if I lean on the lid. Its a top load machine. Could it be the lid switch?
it sounds like the lid switch, get ur model number and purchse one online at repairclinic, or sear, or locally.. hope this helps, i think ur on the rite track bukaroo let me know how it goes
Feb 14, 2010 | Roper RAB5232E
WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
Oct 07, 2009 | Roper RAS6233KQ Top Load Washer
Wont rinse or spin
This machine has a safety feature built in that will often cause this problem.
When it is in spin cycle and you open the lid, it automatically shuts down.
A switch is triggered by the lid when it is opened. This switch has gone bad and needs to be replaced.
The switch is located below the top cover of the machine where the little hole is in the lid opening jam.
Jul 24, 2009 | Roper RAS8445KQ Top Load Washer
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
My washing machine wont spin
How do you open the top to replace the lid switch?
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAB2121KW Top Load Washer Logo
49 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
