Question about RIM BlackBerry Curve 8520 Smartphone
My Blackberry curve 8520 will no longer pair with my Volkswagon GTD bluetooth system. I had the products paired and excepted a call through the system. It worked for about 1 day and then it would not longer pair. My phone thought it was paired but it would not initialise on the Volkswagon system. Any ideas?
When i try do send pictures from other devices to my bb 8520 other devices say's no services found
dude first pair ur bluetooth connection than go to ur media in ooptions select thr recive using bluetooth it will not show that error
Feb 18, 2013 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 8520 stops reciving music halfway through when using bluetooth
firstly check to see if the format of the music you are sending is correct.
secondly make sure devices are both paired together
thirdly and most importantly make sure your blackberry device can receive the bluetooth connection. this is usually done by going to menu>media>select music> options and scroll down and select receive file via bluetooth or something to that effect.
blackberrys are not straight forward when it comes to sending files via bluetooth. hope this helps
Jun 11, 2011 | RIM BlackBerry Curve 8520 Smartphone
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 | Cell Phones
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How blackberry bluetooth connect with other phones
Go to manage connections and bluetooth options, press menu key and select add device. Standard code for pairing is 0000, but you may use any code you like, but give it to other person. Then you can pair. You will not be able to receive any pics/tones, and such until you go to media, press menu key, and select receive using bluetooth. Then it will work.
Jan 15, 2010 | RIM BlackBerry Curve 8520 Smartphone
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
RIM BlackBerry Curve 8520 Smartphone Logo
180 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
