Question about Nintendo Wii Console
Controls do not work - Nintendo Wii Console
  • 8,197 Answers
You need to resync the remote with the wii. Here is how on link below.
http://www.fixya.com/support/r3557442-wii_remote_not_being_recognized_wii
Posted on Dec 12, 2009
  • 3 Answers
If u have the guide manual of ur unit u can read it...... & some other way u can registered it again u can do it by ur self try to read the manual carefully
Posted on Nov 16, 2009
My heater quit working but makes a sound like it's trying to blow. What could be my problem?
the heater works from hot coolant flowing through it so if it stopped working but was working recently , the problem will be in the heater control tap not turning on ( control module )
the blower works of electrical and trying to blow air indicates a problem in the fan speed control ( again a control module module)
if you have a climate control system in the car It may be the climate control module that is faulty as it controls both
Dec 16, 2015 | Cars & Trucks
RAV311 WJ40930 VOLUME CONTROL
Might be the fault to remote control, to respective buttons contacts [inside] it. You have to clean the remote control to make it work. If you wish to get more details about how to check, repair and clean a remote control, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 04, 2013 | Televison & Video
CRUISE CONTROL WON'T WORK ON 2005 CHEVY TRAILBLAZER
check cruise control fuse and check the brake lights see if brake light working because the brake light switch will deactivate cruise control when brakes is applied.if brake lights dont work either fuse blowed or switch bad.if all is good have vechicle code scan because cruise control control by PCM and vechicle speed sensor and thottle actuator control motor.
Apr 17, 2013 | 2004 Chevrolet TrailBlazer
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
On these case,to troubleshoot these problem,there are solved help links.Click the link directly and refer the details to solve these problem yourself,with help of diagrams:------
----------- Horn and Cruise control quit working?
Horn and Cruise control quit working on 2003 Jaguar S-Type? http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These will help.
Thanks.
Nov 22, 2012 | 2003 Ford Expedition
Cruise control don't work
To troubleshoot your problem,there are few help links,provided below.Click the link directly and follow the procedure to confirm the fault.So as per that you can continue further in repairing this issue of cruise control not working.
The direct help links are as follows :-----cruise control not working?
-----------Horn and Cruise control quit working?
Horn and cruise control not working on car?
Horn and Cruise control quit working suddenly?
Cruise control stop working ? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/2005-ford-ranger-cruise-control-not.html
My Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
This troubleshooting help links will help you to confirm the problem.
Thanks.
Feb 13, 2012 | Chevrolet 3500 Cars & Trucks
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
We have tow nodes working as a dual shelf A & B. The control card in B is the main and working probably but the backup control card which is in A doesn't carry the load when we switch the load between...
The control card wasn't work between slot 1to8, they 're called universal card slots (UCS). The control card works only slot 9 or 11 for single shelf redundant configuration. While dual shelf redundant configration the control card works on 9 (shelf-a and shelf-b).
I think your problem was on B-control card. It doesn't support hot standby configuration.
ilker
Jul 15, 2010 | Alcatel Newbridge MainStreet 3600...
Wii Controller doesn't work
Hello my name is Tim Ehrhart, t fix your problem make sure the controllers are on then hold the sync button on the console for approx 5 sec then let go and then hold the sync button on a controller for approx 5 sec., same goes for the other controller, press the console sync button first for every new controller added. I hope this helps you, if this doesnt work then thre is a issue with either the console sync system or the controller. Please remember feedback as I am new and trying to work my way to a higher rep. Thank You
Mar 16, 2009 | Nintendo Wii Console
Wii controllers wont work
Hi, i have just fixed the same problem with my controllers. You must re-sync the controllers. In order to do this, turn on wii, open back of first controller where batteries are and press red sync button, then open small compartment on wii beside where game goes in and press the red button, the first blue light should light up on your controller, repeat for other controllers, making sure to do this process for each controller seperately. Hope this helps!
Jan 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
