Question about Maytag M7DH65B2A Dehumidifier
It is stuck at 20% humidity and wont kick on, what should I do
Why did it stop condensing water?
The condenser can only remove humidity if there is still humidity in the air. What's your Relative Humidity? A manual sling psychrometer is cheap enough to check it.
Jun 14, 2015 | Maytag M7DH45B2A Dehumidifier
Fedders dehumidifier guage problem
call Chas&Son,s appliance repair at 570-379-0993 and they will come out the same day no less okay
Dec 26, 2011 | Fedders A7DH45B2A Dehumidifier
My DH40 unit kicks on and off very frequently while the fan is constantly running. What do I need to do?
Toni, this sounds like the humidity extraction level is set to high. Lower it to 32 - 35%. The fan is running in an effort to recirculate the air. If the unit senses a rise in humidity above the level you have it set on, the compressor will turn on to extract the rise in humidity. That's why I think your level is set to high.
Hope this helped you to troubleshoot and solve the problem.
Jun 25, 2011 | Goldstar Dehumidifiers
I have a GE AHH50LMG1 dehumidifier. It is less than 2 years old. When I turn it on, it displays 20% RH. The fan runs but the compressor does not kick in. I assume that is because it thinks the humidity...
It could be just the sensor, but not likely... many times it is the circuit board that goes bad, making the repair almost prohibitive.. as the circuit board, if you can find one, is often half or more the cost of a new unit...
But you are correct... if the unit thinks the humidity is 20% then it will not bring on the compressor...that is what is happening...
heatman101
Jun 25, 2011 | Haier HD656E Dehumidifier
My dehumidifier kicks on for about 20 seconds and then kicks right back off!
What sometimes causes that, is that the water collection bucket is not sitting in the unit properly/tightly. When the unit turns ON, the vibration causes the bucket to move and lose contact with bucket safety removal switch. Try removing the bucket and reinstalling so that the top and bttom of the bucket fit squarely into the holder and the bottom doesn't tilt downward.
Also, check the humidity extraction level. It may be set to high. Lower it to 32-35%.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Haier 45-Pint Dehumidifier
Is this a low temp model, as it is not dehimidifiying but fan is running
The model you have was made by Fedders for Maytag. The fan runs as a recirculating fan, to continually sense when the humidity level rises, above what have the unit set on. Here in, may be the problem. If you have the humidity level set higher than 50%, that's pretty high and the unit want remove much if anything. It will just continue to maintain that level. Keep in mind, the unit's humidity level must be set LOW, for the compressor to kick on and start removing humidity. By low, I mean 35% or minimum, if your unit does not have an LCD display.
I must caution you, that there is associate on this website that would tell you, that the level should be set on Maximum. Believe me, that simply is not the case. That is, unless you want your home to be hot and humid.
Hope this helps you to troubleshoot and solve the problem.
May 24, 2011 | Maytag M7DH45B2A Dehumidifier
Humidity sensor reads to low and does not kick the machine on. The readout seems to always be at 20% and wont kick on till 35% Is there an adjustment i can make to tuen the unit on?
It probably doesn't need adjusting, It's simply a case that 20%, there's not enough humidity for the sensor to read. But, at 35% there is. I'd say, your dehumidifier is working as it should.
FYI - there is no adjustments to change the factory settings.
Hope this helped you, chu.
May 16, 2011 | Fedders 30-Pint Dehumidifier Dehumidifier
Bad humitidy senser?
replace the humidity stat on water 100 percent
May 07, 2008 | Maytag M7DH65B2A Dehumidifier
20% humidity reading
Hi, I just cleaned my dehumidifier and had the same problem as you. I used a spray water bottle and was not aware that the humidity sensor was being soaked. Very stupid of me!! Luckily I have two same dehumidifiers and used the other sensor to replace the one that I so stupidly ruined, and behold my machine worked again. Now I have to buy another sensor. To make sure we are talking about the same thing, my sensor is white,about 1 inch by 1/2 of an inch. It as 4 wires connected to it. To access it you remove the water tank, you will see 2 screws. Remove those, and pry the front panel loose. Be careful the top of the panel is held by two plastic hooks, they break easy. The sensor is located on the right side just above the radiator, under a produting oval lip which as foam around its rim. The wire colors are red black blue and yellow. Good luck Herman
Jan 11, 2007 | Danby DDR401 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
79 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
