Question about Bunn RL Coffee Maker
Water does not shut off when coffee is brewed
  • 124 Answers
Could be the water supply solenoid is not working properly.
Could be caused by lime scale build up.
Contact a Bunn service center to have the unit serviced.
Also change the inline water filter.
Posted on Jan 03, 2010
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Keurig shuts off as water heats and as coffee is brewing?
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Jun 14, 2010 | Keurig B50 Coffee Maker
Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
Apr 10, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Our coffee maker is only brewing half of the amount of coffee it should. Half way through the brewing, it shuts off. We've cleaned it with vinegar, but it still happens intermittently. It's actually...
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Dec 13, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Auto shutoff
some of these coffee makers have feed tubes, which can be seen in the rear water reservoir, that feed the hot water to the grounds. some of these tubes collapse when the boiling water passes through them , then kink , causing the water to stop flowing untill it either cools or is straightened. To check and see if this is occuring.. look in the back reservoir, if there's a tube running through it, note how soft it gets as it starts to brew.. be careful the water inside the tube is hot.. This indentify why it stops brewing partway though..
Sep 21, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Brews most of the water than stops and shuts itself off
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Mr. Coffee TFTXC85
run 2 cups of vinegar through the coffee pot brew it do it twice. this will clean the calcium out. then rince out out and brew one batch of water to clean.
May 22, 2008 | Mr. Coffee TFTX85 Coffee Maker
Bunn RL Coffee Maker Logo
73 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
