Question about Frigidaire FEQ332E Electric Dryer
My Frigidaire dryer has no heat. It was working fine last week and I could look inside and see it was ''red'' around where it was heating from the back part. 1 day later, no heat & no ''red'' ring in the back. Can you tell me if it is my coil? And how much would that be? The unit is only about 2 years old.
    Scholar:
  • 86 Answers
Check your breaker box. Dryer will run on 120 volts but will not heat without a full 240 volts. If that's not your problem, it's best to hire someone. I only say that because this brand of dryer is not easy to work on.
Posted on Nov 17, 2009
Testimonial: "Thank you. To bad I already had my boyfriend try and rip it apart. Ill just wait till my pops comes up for Thanksgiving. That should make his day!"
  • Mark Truitt
    Mark Truitt Dec 16, 2009
    Just checking in to see how the outcome went. Was your Pop able to find the problem?
  • tukkenrowl Jan 01, 2011
    tonight i had the same exact problem, and by switching the 30amp breaker off and then back on fixed it.. thank you very much appliancguy you hit the nail on the head :P
Tip
Maytag Neptune Dryer Lights up (8.8)
Last week i had my Neptune dryer come up with this 8.8 error code and wouldn't start. so i called the Maytag people and they claimed there is no such error code so they sent out a tech (free of charge ) :) and he tested it and found nothing wrong and i had remembered that last week it was working fine when it was warm outside but now that it is cold below 40 deg. it does not want to work so i thought that this has something to do with the the dryer sitting in the room outside where it is cooler that it is inside so i got a heating pad and i placed it under the sensor that sits on the bottom of the dryer to see what would happen but no avail
so then i moved the heating pad to the control panel area on the back and turned on the heating pad for 20 minutes on high and came back and tried the drier and wow it now works so called the Maytag people back and they sent out a rep and i showed this to them and they were amazed on how this worked they are currently working to solve this issue
Hope this tip will help
Best regards Mike
on Jan 16, 2010 | Dryers
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
Frigidaire dryer, looks like the heating element is good. no heat, all else works fine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 12, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire dryer model#FEQB2152FEO. A big white plastic piece broke off around the inside front. It looks white and circular and it seems like it was maybe a seal or ring around the drum?
did you ever get a solution for your problem with your dryer? i have same frigidaire dryer model number and the plastic ring on the front inside just broke off in mine last week and im not sure what to do to fix it.
Apr 11, 2010 | Frigidaire Dryers
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire FEQ332E Electric Dryer Logo
814 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
