Question about Microsoft Xbox 360 Console
Red flashing lights
I have had my xbox 360 for less than a year. i just turned it on and the top left, bottom left, and bottom right red lights around the green power button are flashing, and the system doesn't work.
  • 975 Answers
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Posted on Nov 16, 2009
3 red light flashes. left top. left bottom and right bottom. Problem occurs when power is turned on. Read manual and contacted you.
You've got the three red rings.
They light up when there is a general hardware failure in your Xbox.
If your xbox is under 3 years old, contact Microsoft and they'll service it.
If it's over 3 years old, wrap it in a towel, turn it on and let it run.
This is a simple, yet effective temporary fix.
Mar 09, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
The bottom right light is blinking red everytime i turn it on
e74 at the bottom of the screen?if your xbox is less than 3 years old send it back to microsoft as they have extended the warrenty period to 3 years, e74 is code for graphical issues could be the graphics card. hope this helps.
Nov 17, 2009 | Microsoft Xbox 360 Console
Wont load,blinking red light on the power button
if it is the top left, bottom left and bottom right lights blinking red, this means that there is a hardware failure in your xbox 360 and there is no current way to fix this. i recommend that you send it in to xbox to see if they can do anything, and if not, they will possibly send you a new xbox 360.
Sep 27, 2009 | Microsoft Xbox 360 Console
My bottom right light on my xbox 360 is flashing red!!!
take a look at this website, see if it helps.
It makes all the errors clarified. i found out that my disc drive crapped out and that its overheating because of it, I have two red lights on my left.
www.xbox-scene.com
Sep 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesn't work
you have the red ring of dead which means your xbox is dead. Call xbox support and if your xbox is still under warranty theyll fix it for you.
May 20, 2009 | Microsoft Xbox 360 Console
2 red lights w/green light
The problem is the black screws on the bottom of the frame that screw into the X-Clamps. Most of the time, you usually don't have to even put the black screws back in. However their can be exscruciating headache inducing problems with fine tuning the black screws. If you do end up needing to put the black screws back in, I suggest to start with one @ a time, starting with the bottom right screw. ( thats with the 360 standing vertical with the dvd drive faced toward U.) The tightness can range from almost as tight as you can possibly get to soooo!!!!!! loose u can't possibly imagine how its doing anything at all. The best way to do this is, with the 360 hooked up, (and the case left off) take the small white plastic frame off that covers the power button, start with the screw loosened and then proceed to turn slightly like an 1/8th of a turn, then power on and then turn off if 2 red or 3 red ring proceeds and then repeat. You shouldn't have to put all the black screws back in, mine only has bottom right bottom left and top left, and are incredibly loose. My friend however has bottom right only and is tightened only about 1/2 way.
Sep 21, 2008 | Microsoft Xbox 360 Console
Xbox 360
I would recommend sending this back to microsoft if you can. If you can't for some reason. Ebay has many sellers who will fix 3 lights of death for much cheaper that MS will.
- John
Jun 21, 2008 | Microsoft Xbox 360 Console
Flashing
You have the lights of death, but dont fear...just get in contact with xbox they will supposedly replace it for free, because its a defect...
Got this off XBOX.com
Xbox 360: Three red lights flash on the Ring of Light View products that this article applies to. function loadTOCNode(){} Article ID : 907534 Last Review : February 22, 2008 Revision : 6.0 SYMPTOMS loadTOCNode(1, 'symptoms'); You see three lights on the Ring of Light (RoL) flash red on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue: 1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Xbox 360: The power supply light is red 906102 (http://support.microsoft.com/kb/906102/) Xbox 360: The power supply light is orange 906103 (http://support.microsoft.com/kb/906103/) Xbox 360: The power supply light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again.If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support), and then click Console Repair? in the upper-right section of the Web page.
Note The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Mar 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
105 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
