Question about Dryers
My whirlpool duet front load dryer is not heating up. The drum moves but there is no heat. how do I fix this?
    Scholar:
  • 86 Answers
Check your breaker. The dryer will spin at 120 volts but will not heat without the full 240 volts. If that's not your problem there are some fuses behind the bottom front panel that need to be checked, along with the heating element. You'll need an ohm meter for this. If its not your breaker, its best to hire someone. Good luck...
Posted on Nov 17, 2009
My whirlpool duet gas dryer will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
MY DUET DRYER IS NOT HEATING UP. WHAT COULD BE THE
no heat at all probally element or the thermostat on the element.if heats but takes long time outside venting probally plugged up.make sure your getting 220 v to dryer before anything
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Inside of the dryer is cracking- huge holes!
the drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9250
more than likely a short in the user interface
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
188 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
