Question about Sony Playstation 3 (PS3) Console
Internal fan won't turn & the system gets hot in about five minutes
Dude, it sucks but you might have to disassemble it. go to youtube and search ylod and go to the first vid to see how to disasemble it
Posted on Nov 26, 2009
  • 975 Answers
Heres one solution , try this :
When the PS3 is in standby (red light on) press and hold the power panel until it beeps again. This reset's your video settings. hope this helps , AJ
Posted on Nov 16, 2009
Play system for 30-45 minutes and turns off randomly
This may be a problem with overheating. When the system overheats, it shuts off automatically in order to prevent hardware damage. When your system crashes, try feeling it to see if it is warm or very hot. If this is the case, you may want to move it to a more open area or try putting a fan onto it to reduce the heat. If it doesn't feel hot, then it may be a problem with your fan. If you do not hear a fan running or can't feel the air while playing the game, your internal fan may be busted. I suggest going to a repair store (such as Best Buy) and checking out the issue if it does turn out to be an internal issue.
Feb 19, 2014 | Microsoft Xbox One
I have dell inspiron mini 1012 , when i turned it on booting it works then after 10 min it freeze, so i turned it off and tried to power on it worked but it didn't find the operating system, i tri
It sounds like your system might be running hot. Do you hear the fan running? If so it will turn on after it has cooled off, but once it gets hot it will turn off. If you immediately try to turn it back on, it won't work until the system has cooled off.
Laptops overheat because of the following problems:
1. Dust has clogged the Fans, Vents, CPU & Heat Sink Area
2. The FAN has stopped working
3. The Thermal Paste around the CPU and HeatSink has either dried up or is too thin to keep the system cool.
Try a can of compressed air and blow out the areas you can get to around the vents. You'll have to take the laptop apart to get to the Fan, CPU and Heatsink
Mar 30, 2012 | Dell Inspiron Mini 1012 Netbook...
Hi, I ahe a dell computer model number dccy, i want to know why it turn off by itself, when it get to hot, when i have more than ten minute working with it, why if turn off
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 16, 2011 | Antec Computers & Internet
I have a 2001 Mazda Tribute. The blowers for the fan work just fine, but the air never gets warm. Any idea what it is?
your heater core could be clogged. flush out your whole cooling system and hopefully that fixes the problem
Dec 16, 2010 | 2001 Mazda Tribute
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Whilst cooking strong smell of plasic & cabinet became too hot to
May be a shorted metal stirrer fan bearing located within the wave guide that feeds microwaves into the cooking area. If the oven is run without a proper load (water, or food), the voltage of the microwaves increase considerably causing things to arc-over inside the wave guide. You usually can't see the stirrer bearing short as it occurs internally.
Jul 23, 2009 | Panasonic NN-H765 Microwave Oven
Fan quits and the compressor still runs
is this a split residential system. it sounds like you are talking about the condenser fan either way it seems like the fan is overamping and tripping on thermal overload which is a device in the motor that protects itself. when you shut it off for a while and turn it back on does the fan work. if you turn it off then turn it right back on does the fan work. when it shuts off is the motor really hot. if possible, and you know how, check amp draw. typically you can find the rated amp draw on the motor nameplate.
May 27, 2009 | Carrier 52CQ315 Air Conditioner
Gateway 450SX4 Notebook Overheating Problem
the best thing for you to do is purchase a cooling base its a platform with fans in it to blow air through the laptop all the time. these are greast for the newer faster machines they tend to run hot. you will also love the difference it makes in performance
Dec 11, 2008 | Gateway 450SX4 Notebook
Power supply repair HP Pavilion s 7210 n Slimline
need fans on main cpu maby died replace with ball bearing blow all the dust out of it with big vac on blow ok and go nuts blowing dust out add hiend nice quilty fans mascool on newegg 10 pack 12 bucks free ship cheap nice need air flow getting to hot and power suplly cant keep up get nice dual rail one ok
Jan 10, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
