Question about Car Audio & Video
My son has a Schwinn Currie electro drive S 4.0 scooter that doesn't work any more and we can't figure out why. can you help us? Kelly Luedde Houston Texas
aparsons89
  • 40 Answers
SOURCE: Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Posted on May 10, 2009
aparsons89
  • 40 Answers
SOURCE: scooter won't run
Hi, Well it sounds like you have a wire not connected or the Twist throttle part is bad. The best thing is to use Volt meter on each battery and make sure they are at 13 volts of more. If they are 11-12 volts the batteries are no good. When you turn the switch on does it make a Click sound? Take off your battery access panel it is where you put your feet. Your batteries have a red and black wire with a wiring harness attached to them. This is where you want to make sure they are plugged in. If they are Plugged in Your Scooter has to Have a Blown Fuse. Check these out and get back to me with what you find. Batteries last 1 year if you take good care of them.
aparsons89
  • 40 Answers
SOURCE: gt trailz currie scooter needs good battery
Hi, Is this the 12 volt 10 amp battery? If so go to ebay to buy this it will be much cheaper. You DO NOT have to buy the battery from Currie. For troubleshooting that control box, I will give you an link for it. http://www.electricscooterparts.com/troubleshooting.html
Posted on May 13, 2009
  • 336 Answers
SOURCE: i'm trying to figure out what kind of battery a
Your scooter uses dual 12-volt, 10-amp hour sealed recyclable lead acid battery.
You may want to open below link to see some examples of batteries suitable to your scooter.
http://www.batteriesplus.com/products/78-0/6069-Electric-Bike-Scooter-Battery/252604-Schwinn/S180-Electric-Scooter/1.aspx
Regards,
Jeep Brainy
Posted on Sep 11, 2009
SOURCE: Manual for Schwinn Mongoose z350 electric scooter
Thats what mine is doing whats wrong
Posted on Jun 26, 2011
Just bought a 2009 schwinn valo 50, it sparks but doesnt start would it more likely be stator or CDI?
Hi, Kelly and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2008 schwinn valo 50 spark problem Scooter Doc Forum
http://www.manualsonline.com/support/schwinn-motor-scooters
Schwinn Motor Scooters Hope 50CA06PK Manual
Currie Technologies
Schwinn hope 50 User Manual
Mar 17, 2017 | 2010 Schwinn Valo 50
Install battery
First make sure the scooter is off.
Unscrew and take off the deck
Unplug and remove the old battery pack
Put the new battery pack in and plug it in, using the same connection as the old batteries pack.
Screw the deck on and your done!
Oh, and make sure you give the battery a good charge(the full charging time). The first charge of a battery is the most important one.
May 16, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
My Mongoose z350 electric scooter goes from full charge to empty in about 20 seconds. I can turn it off and back on and it shows a full charge every time. What is going on with it?
Mar 24, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
I need to assembly the wiring for the batteries. what is the method for connecting the 2 positive and 2 negative terminals?i have the schwinn S350 scooter.
Scooter positive terminal to battery 1 positive. Scooter negative to battery 2 negative. Battery 1 negative to battery 2 positive.
Jan 28, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
Mongoose Pro Scooter will not go
you can have the battery tested for its voltage with an voltage meter and see if it is giving enough output for its purpose, but from the sounds of what you are saying it seems the battery isnt holding enough to power the scooter
Sep 03, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Schwinn S350 Scooter batteries
Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Schwin scooter not running properly
If the battery is old its likely that it needs to be replaced. Also, if batteries sit in the cold in the winter or are exposed to high heat they can be damaged. Try checking out http://www.batteryinternational.com/electric-scooter-batteries.html for a scooter replacement battery.
Jun 09, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Gt trailz currie scooter needs good battery
Apr 19, 2009 | Electric Currie EZIP 500 Scooter
I have an S500 schwinn electrodrive scooter, what kind of battery
call up currie tech there will be a number on your product you will have to order the parts
Jan 15, 2009 | Transport Schwinn Rechargeable Portable ...
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
