CHECK OUT THE DRAIN MOTOR PUMP , it cpould be clogged , located where the drain hose is connected inside , youre gonna see 2 hoses connected to thi small motor , hope it helps , AJ
I have a fridgedare front load washer , I put a heavy blanket it it and now it wont spin/drain Turns on but will not do anything. Help!!! any ideas
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
