Question about Samsung TXR3079 TV
There was a power surge ,a black and then a blue line came on the screen,tv went off. when switch on a blue line appears, thanx
    Scholar:
  • 63 Answers
I assume by a blue line you are seeing a seeing a single line left to right across the screen. If this is the case it is a failure in the vertical deflection circuitry. There is no simple repair as a part or parts have failed. In the event of a "power surge" there could be a number of components affected. The unit would really need to be diagnosed by a competent technician. I have worked on many of this model and they are certainly repairable, but probably need two people to move it as they are very heavy as you know. I would get an estimate on the repair and make a decision based on that.
Posted on Nov 16, 2009
Blue screen, no picture. What's wrong?
The board where the power button is located (same board for the other buttons too) is probably bad. It's all one board, which tells the power board to come on. If this happened after a power surge, and you're not using a surge protector, multiple boards can be bad. (You can't just plug these fragile TV and Blu-Ray players into the wall outlet. Eventually a surge will destroy them). Ps... A lot of people are suddenly making this same complaint with Vizio TV's.
Mar 03, 2016 | Vizio Televison & Video
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
Black screen blinking line in upper left corner
you just need to re-install the Operating System from recovery cd
Dec 19, 2012 | Dell Dimension 8250 PC Desktop
Blue lines in screen
Follow the steps below after verifying that the issue is occuring on other channels and other video sources.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved, service may be required.
Sep 22, 2009 | Sony KP-51HW40 51" Rear Projection...
Hitachi 55HDS 55 Inch Plasma Picture Problem
Hi Mhansen884,
This type of failure is due to a defective upper and lower scan boards.
Check the link provided to see what the parts look like and or to find the part numbers if you would be DYI,
Mar 03, 2017 | Hitachi 55HDS69 55 in. Plasma Television
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
Sound, but black screen
you have lost the video, either because the vertical section or the deflection circuit stopped working. if the power supply is independent from the others circuits is going to work and the video does not
Aug 06, 2008 | Hitachi 32UDX10S 32" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
Samsung TXR3079 TV Logo
Henry  Thomas
Henry Thomas
