I had the service done (oil change)specifically asking to check all fluids 6 days ago on my 2007 VW Jetta 2.5 sedan. after driving 288 miles from Ca to NV and back and then 40 miles Santa Clarita while on the freeway my engine light came on I kept An eye on the gayges and when I got to my destination I popped the hood there was a little smoke and smell when I looked under the car a quite a large puddle of redish color oil. My question is: Is this transmission fluid? Could this be a fault of oil change place not properly putting the plug (new one)back on tight?
    Brigadier General:
  • 3,854 Answers
Yes the fluid is transmission fluid that is leaking, not knowing the year of your Jetta. The newer Jetta's have a sealed transmission and needs to be checked by a scan tool, here is the instruction.
Locate the transmission. On the low right hand side (passenger side) of the transmission is a small service plug. Place a drain bucket strategically beneath the plug and remove it with a hand wrench. A small amount of transmission fluid should trickle out indicating that the fluid level is okay. VW recommends during these maintenance service interval checks to test the temperature of the transmission fluid using a scan tool. VW also recommends replacing the transmission check plug each time it is removed. If any transmission fluid is needed to be added, locate and remove the fill plug that is on the front left upper corner by the oil pan. Add a little bit of fluid at a time through this portal while watching the check level portal and as soon as it begins to trickle out from that outlet, the transmission fluid level is full.
Good luck and hope they did replace the check plug to ensure a good seal again.
Posted on Nov 16, 2009
  • 132 Answers
YOU SAY THEY DID A OIL CHANGE BUT YOU DD NOT SAY IF THEY CHANGED THE TRANNY FLUID, IT IS TRANNY FLUID AND IF THEY DID CHANGE THE TRANNY FLUID THEN TAKE IT BACK TO THEM
How do you add transmission fluid to a 2007 VW Jetta 2.5L?
There is a brass colored plug facing skyward on the left (US driver's) side at the rear of the 6 speed automatic transmission. This plug is removed with a Torx tool (I cannot recall but is in the range of a #40). This plug provides a direct access to the case of the transmission and if you can find a suitable small funnel (I made an adapter) with a small piece of fuel line, etc. you can introduce ATF into the tranny. The transmission holds about 5 liters of special VW fluid. All the transmission experts I have talked to say to use the VW fluid. It is expensive but less expensive than a new valve body, etc. There is a overflow tower in the drain plug. I changed the fluid by dropping the pan. There is a magnetic plate trap in the pan. It will be covered with metallic particles. VW is dead wrong about "fluid for life". Change it at 80K to 85K miles.
Nov 08, 2012 | 2007 Volkswagen Jetta 2.5 Sedan
Where is the oil pump located on a 2007 Volkswagon Jetta
its located inside the engine there is an oil tank type under the engine with about 15 to 20 bolts this is called sump you have to remove it to get to the oil pum But dont try this at home its a technicians job
Feb 02, 2011 | 2007 Volkswagen Jetta 2.5 Sedan
What is the oil change interval for 2007 Volkswagen Jetta Wolfsburg edition? Looked in Manual but it says to see the maintenance booklet which I do not have. Thanks!
Use synthetic quality engine oil and factory filter and change oil every 12.000 miles.
A 5W30 will work well.
For more oil information check the site of 'The Oil Guy.'
Jan 15, 2011 | 2007 Volkswagen Jetta 2.5 Sedan
Hello i just bought a car 2007 VW JETTA 2.5 2 days ago and it turn off on me twice why??? I have a light that shows like this ( ! ) and stays on, what is it??? Also another light that saids DRL OR DLR (i...
It's telling you that there's a serious fault and that the vehicle must go to the nearest dealer (DLR). Perhaps you should have a polite word with the seller and ask for your money back.
Sep 22, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
What viscosity oil for vw jetta 2007 2.5l
sae 5/40 semi synthetic is fine,change oil every 10k/yearly regardless of service book,or service regime set on computer.engine will last longer....
Apr 19, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
How do I add transmission fluid to a vw jetta 2007
on a 2007 VW Jetta with a 2.5 engine. How do you refill the transmission. After draining the pain, cleaning it ,changing the filter and reinstalling the pan. I can not find a way to check the fluid level or to refill the pan to the proper level.
Jan 07, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
My '97 Jetta 1.8L came without its "Service Manual" which is where VW apparently chooses to publish the maintenance schedule. When it was available from the dealer, it cost $4.95, so it can't be big. Do...
I don't know where you can find one I searched but could not find one. Oil changes ever 3000 miles. Spark plugs and air filters every 30,000 miles, Timing belt every 100,000 miles. Serpentine belt check for crackes on the groved side at every oil change, if any sign of wear change. Top off all fluids when oil changes are done.
Dec 30, 2009 | 1997 Volkswagen Jetta
At how many miles should I change my transmission oil?
You should have a service manual that came with your vehicle when you purchased it. It will tell you how often you should change the different fluids, either in months or the amount of miles you have put on the vehicle.Most dealers have different schedules. If you don't have a records manual, you can call the dealer and they will tell you this. My vehicle says every 12,000 miles or 6 months which ever comes first.I hope I have been of some help to you.
Sincerely, shastalaker7
Oct 31, 2009 | 2007 Volkswagen Jetta 2.5 Sedan
Transmission won't shift fron 1st, 2nd or 3rd correctly!
I'm no expert but it sounds as if you might have some moisture (water) contaminating your tranny fluid. I'd first try having it drained, flushed and refilled with fresh fluid. Preferably after it has been warmed to room temperature - -2 brrr.
Dec 22, 2008 | 2004 Volkswagen Jetta
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
