The door will close when no tape is present but when I put a tape in the motor just barely moves and stops. When I push eject with no tape in and the holder rises one of the tape rotors keeps spinning for a while then shuts off.
What happens if the camcorder is plugged into an electrical outlet.
Same Problem
Jan 22, 2009
-   i have a sony hc37 and it won't close at all - with or without tape! -   shandyw
Nov 17, 2008
-   Same problem here, except the model number is a ccd-trv37. I only used this camera for a year before it broke...sucks!!!
-   Nostrodomas
Jan 15, 2008
-   Same problem with model CCD-R21. Tape head spins like crazy for seconds or so but carrier does not move down into position, then ejects outward as it is supposed to. Removed door and doesn't appear to be anything that is blocking anything. -   Toxictom
Jan 11, 2008
-   Have exactly the same problem on a CCD-FX310. The door will close when no tape is present but when I put a tape in the motor just barely moves and stops. When I push eject with no tape in and the holder rises one of the tape rotors keeps spinning for a while then shuts off.
I have a non-functioning Sony CCD-TRV67. I'm trying to locate another camera that will play the...
(More)
I have a non-functioning Sony CCD-TRV67. I'm trying to locate another camera that will play the tapes I have. Any advice?
I changed the tape, cleaned the head and tried and external mic and still will not pick up audio...
(More)
I changed the tape, cleaned the head and tried and external mic and still will not pick up audio while recording.
old hi8 sony handycam playback not working i have it on the player mode editsearch works, rec. works...
(More)
old hi8 sony handycam playback not working i have it on the player mode editsearch works, rec. works playback does not any quick suggestions
