Question about Refrigerators
I have a 12 year old GE Profile Refrigerator with top freezer and water/ice maker in top freezer door. A puddle of water appears every few days on right top refrigerator shelf. How can I fix this?
  • rgeffken Nov 16, 2009
    Caralymonty,
    It looked sounds like a reasonable explanation but it looks pretty tough to expose the top of the drain line. In my refrigerator it looks as though I might have to take out the ice maker to get the bottom shelf out and expose the top of the drain. I checked the back of the line and the tube to the bottom drain line is not plugged. I'll try your wire and air solutions and see if they work.
    I was able to clear the clog from the back of the refrigerator. There was a s shape union that connected to the drain tube which was able to be removed by twisting 180 degrees. It contained the clog. Thanks
  • 3,741 Answers
Yes
The water accumulation is caused by a blockage of the freezer drain line. Why does a freezer need a drain line? Do you not have a frost free unit? The freezer, on a timer will go into a defrost cycle. The moisture has to go somewhere... and that is down a drain to a pan in the very bottom of the refrigerator... From there it is quickly evaporated by the fan / compressor heat. Now, you have to find that drain line. I start by taking out every thing in the freezer / refrigerator. Then looking in the area above and below the floor of the freezer, try to find a place where water would naturally flow out. It could flow out the back of the space down a usually white plastic tube. You may have to take any screws out of the floor of the freezer, and side walls to expose this drain... It is always under the evaporator coils inside the freezer... It can not be anywhere else... It is there trust me... Once you find it, you need to clear it. What has happen is the green or black mold has entered the water line and reproduced to the point it is clogging the drain. THIS HAPPENS. don't worry about that. Every time you open and close the fridge doors, you bring air, and anything in it, in and out of the tube, it can not be helped. To clear the line is not always easy. You might try to pour hot water down the drain. You might try pushing a flexible wire down the tube. Do not force as you could break something... You may have to locate any junction, bends, elbows where the line attaches to something else and loosen the line and force air into it to clear it up. I have at the most difficult situations, remove the entire drain tube and force air into it to clear a solid mold clog.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 16, 2009
Hi, we just purchased an 5 year old GE profile refrigerator with full door/bottom freezer from a private party. It was working fine at his house. The refrigerator has a loud buzzing every 1/2 for a few...
The buzz is most likely coming from the water valve that feeds the ice maker. If the ice maker is not being used the buzz will continue unless the power is disconnected to the valve. It does not hurt anything but can be annoying.
If the ice maker does not have the shut off handle (arm) to lift then a solution would be to unplug the ice maker itself. If you look at the ice maker in the freezer it is usually held on by 3 screws to the side wall. If you remove these screws there will be a wire plug that you can unplug and remove the entire ice maker and free up room. With it disconnected the buzz will stop.
Apr 18, 2010 | GE Profile Stainless Bottom-Freezer...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Dec 14, 2008 | GE Profile Arctica Stainless Steel Top...
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
