Question about Motorola Mobility Boost i415 Cellular Phone
Im trying to unlock my boostmobile sim card so i can use it in my at&t phone. i need an unlock code
I have several older Boostmobile phone like a few razor flip phones,samsung flip phones and a few newer ones with cracked screens. I need to desperately retrieve old contacts,photos and text messages from...
I know that they charge for this (it's only like ten bucks) but the verizon store has a machine that will move all info from one phone to another or to USB/SIM card regardless of the carrier. Go there and you'll be ok : )
Jun 06, 2014 | boostmobile.com
Im locked out my phone because of the puk code
TThese directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Oct 07, 2011 | LG KS360 QWERTY Keyboard Phone BRAND...
I need the puk code and new pin number i tried puttin a lock on my phone and i didnt know the code to change it because it was a used phone and now im locked out of my phone because now i need the puk code...
Sep 25, 2011 | Samsung SGH-A877 Impression Cell Phone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
I have a boostmobile simcard and i want to put the tmobile simcard inside the sidekick slide.but when i do it ask me for a special code is there a special code for me to start using it?
you actually need to unlock your phone to use the simcard not just a code. boost mobile and tmobile run and different networks to its not as simple as putting in a different sim card.
Mar 25, 2011 | Cell Phones
How can i put my boostmobile sim card into motorola ic502
you must UNLCOK the phone. Also the other phone must also be a sim style phone. Any phone can be unlocked and used with your simcard. To unlock the phone is different for each phone. So, you need to unlock the motorola ic502 so it can read your sim. The cell company can give you that code if you have owned the motorola for more then 90 days but you can also unlock it with out the need to call the cell company. I would need a little more info or from what I have said above you can start to google around for it.
Dec 28, 2009 | Motorola Mobility ic502 Cellular Phone
I'm trying to transfer my Boost sims card to a Tmobile Samsung Behold but it asks for a network code? My IMEI for the Behold is 35191503181090/0 03
Boost Mobile runs on an IDEN network where tmobile runs on a GSM network. Unfortunately the boostmobile sim card will only work in nextel and boostmobile branded IDEN phones.
Dec 09, 2009 | Motorola Mobility RAZR V3
I NEED THE 16 DIGIT CODE TO UNLOCK MY LG CU920
How to enter Unlocking Codes for LG Phones for Various U.S
Below are instructions that work for most network providers.
How to Unlock LG (most models):
1:Insert not-allowed SIM card
2:Power on the handset- phone will display “phone restricted”
3:Select “Cancel” - phone will display “phone restriction code”
4:Enter the SIM unlock code
5:Select “OK” - the handset is now successfully unlocked
How to Unlock LG KG245 (Vodafone Australia)
1:Insert a Vodafone Australia working SIM card.
2:Ensure the phone is charged and then switch the phone on.
3:Optional Step: If the SIM card has a PIN, enter your PIN number
4:Wait for the phone to power up then enter 2945#*7101#
5:Select Menu , then go to Settings > Security > SIM Lock > Network
6:Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7:The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Unlock LG KG800 or TG800 Chocolate:
1:With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2:Go to: Settings>Security>SimLock>Network
3:Select deactivate. Enter the unlock code,
How to Unlock LG C2000:
1:Power on the handset - phone will display “phone restricted”
2:Select “Cancel” - phone will display “phone restriction code”
3:Enter the SIM Unlock code
4:Select “OK” - the handset is now successfully unlocked
1:With allowed sim card in the start menu type: 2945#*3311#.
2:Handset shows saved, then return to startup screen
3:Press Menu key, choose Settings > Security > Sim Lock> Network eactivate, handset will now show ‘Enter NCK’
4:Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1:Switch ON your phone with a not allowed SIM card.
2:Compose: 277634#*#.
3:Go to menu “SIM Lock”.
4:Enter the unlock code, which you can buy any online store .
1:With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2:Select ‘Sim Unlock’ menu #
3:Enter NCK code then validate
1:With a not allowed sim card enter Pin code then validate, type: 277634#*#
2:Shows test menu
3:Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4:Handset shows ‘Enter NCK’
5:Enter code, then hit OK.
1:To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2:Enter the code
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1:Insert non-Cingular SIM card.
2:Power on the handset. Phone will display “Invalid SmartChip”
3IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4:In Idle screen, enter 159753#*#. Phone will display “Enter NCK, Remaining 5
5:Enter the 8 digit SIM unlock code, which you can buy any Oline phones.
6:Select “OK”. The handset is now successfully unlocked
How to Enter Unlock Codes on all other LG cell phones:
Switch ON your phone with an allowed SIM card
Then compose:
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
Go to “Menu” and then to “Settings”
Then select “Security”
To finish select “Network Provider” and select “Deactivate”
Enter the unlock code, which you can buy Online store unlock-cell-phones.
How to Enter Unlock Codes on all other LG U400 Shine (2 codes needed):
1:Insert the network SIM in the handset which works with the phone (from the locked carrier).
2:Enter 2945#*88110#.
3:The phone will then prompt ‘Unlock sim’. Press OK.
4:The phone will then prompt ‘Network Unlock’. Press OK.
5:The phone will then prompt- ‘Input Network Control Key’. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
6:It should give you the message: Success.
7:Come back to the main screen and Enter 2945#*88110#.
8:The phone will then prompt unlock sim. Press OK.
9:The phone will then prompt Network Unlock/ Lock but if you scroll down
10 :you will see a message Enter SP Lock. Enter SP Code.
Then press OK.
How to Enter Unlock Codes on all other LG KE970 Shine:
1:Switch ON your phone with an allowed SIM card
2:Then compose: 2945#*9701#
3:Press CALL.
4:It should you ask you for the code.
How to Enter Unlock Codes on all other LG TU720 Shine:
1:Put in a non-allowed SIM, phone says invalid SIM card
2:Now enter *#865625# then enter your 16 digits code.
How to Unlock LG KG800 Chocolate Without a Code (not reliable):
1:Insert SIM from the network that it is locked to.
2:Turn on phone.
3:On home Screen, slide up phone.
4:Type 2945#*#
5:ENG. Mode menu should appear.
6:Go Down to Factory Reset. Select it. May take a few minutes to reset!
7:This will reset the phone back to before the phone was locked to a network.
8:The phone will automatically restart (the network logo at start up will not change).
9:Now insert any SIM card and the phone should turn on normally
10:The phone is now unlocked and you can customize the setting as you like
How to Unlock LG Vu CU920
June 11th, 2008 by Eric
On the AT&T Network, to unlock the LG Vu or CU920, it’s pretty simple:
Enter *#865625# then the 16 digit unlock code*
*The 16 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
Dec 05, 2009 | LG Vu CU920 Cellular Phone
I JUST GOT AN I 930 BUT I HAVE A BOOSTMOBILE SIM CARD
have you try turning the flight mode off on the phone setting
Jul 26, 2007 | Nextel i930/i920/i870 Stereo Headset [OEM]...
Motorola Mobility Boost i415 Cellular Phone Logo
921 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
