My hotpoint water symbol is flashing - Washing Machines
  • Washing Mach... Master
  • 3,463 Answers
Check the water supply to the washer, make sure the inlet hose/hoses are not kinked or restricted in anyway.
Make sure there is sufficient pressure at the inlet valve..
Check the inlet valve filter is clean.
Please rate my solution.
Thanks.
Posted on Nov 16, 2009
Flashing key symbol
wire may have fallen off switch, or shorted
Feb 08, 2013 | Hotpoint WMA74 Front Load Washer
Symbols on fridge freezer- i have a flashing symbol that looks like a test tube with a rounded end on hotpoint fridge freezer- what does it mean?
Is the water draining from the unit? It sounds to me like that symbol is telling you the water that has accumulated from removing the moisture in the conditioned air is full and needs to be drained.
Aug 03, 2011 | Danby Portable Air Conditioner
Symbols on a hotpoint WD23 washing machine
hello,
what this indicate is that window / door are not properly close to there position that is free ton air at 23 degree
please make sure that doors are properly close before use and also there should be no over flow of water on the panel that is control unit .
thank you.
Aug 02, 2010 | Hotpoint Washing Machines
Hotpoint WT960 has the H2o symbol flashing it has water and no pipe kinks
Make sure that the water pressure is o/k, and that the valve is fully turned on.
Also check the filter in the inlet valve, you wilave to remove hose to do this.
Mar 29, 2010 | Hotpoint Washing Machines
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Thanks.
Nov 07, 2009 | Washing Machines
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
WMA61 Hotpoint Washing Machine 'Red Tap' symbol is flashing
well if your sure the other end is connected to the tub and is tight then id replace the switch its out of calibration it works off positive pressure from the water in the tub if you can blow in it and it actuates doesn't mean its working off the right pressure from the tub
Jan 27, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
