Question about PNY 2GB microSD Memory Card
I recently bought a micro mini, transfered pics from cell phone, put micro into the min adapter and into my laptop, and laptop did not see it. Tried another mini disk and the drive works...
    Sergeant:
  • 225 Answers
See if the adapter has a small switch on it (for wright protect) an move it . if this not solves the problem try another adapter (ask somebody to borrow one). if it`s still not working your MicroSD may be compromised, but this is really hard to happen.
Posted on Nov 16, 2009
How do I upload pics from my cell phone to my laptop
There are three ways that you can use enable for you to transfer pictures from your cellphone to your laptop.
1. By using a connectivity cable. It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.
A connectivity cable looks like this.
2. Bluetooth. Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth.
CLICK HERE
3. Memory Card
SD cards are used in many cell phones.
Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive.
Here's the instructions on how to do that:
1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card.
2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter.
3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.
Hope this helps.
Please don't forget to rate this solution. Leave your comments or suggestions on how I can improve my service.
Thanks
Jan 28, 2011 | Cell Phones
Tip
How to Transfer Files from Cellphone to Laptop and Vice Versa
<span>There are three ways that you can use enable for you to transfer files from your cellphone to your laptop or vice versa.<br /><br /><span style="font-weight: bold;">1. </span> <span style="font-weight: bold;">By using a connectivity cable</span>. <br /><br />It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.<br /><br />A connectivity cable looks like this.<br /><br /><img src="carloadrian_2.jpg" /><br /><span style="font-weight: bold;">2. Bluetooth</span>. <br /><br />Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth. <br /><br /><a href="/../support/t8013435-connect_laptop">CLICK HERE</a><br /><br /><br /><span style="font-weight: bold;">3. Memory Card<br /><br /></span><img src="carloadrian_4.jpg" /><br /> <a><br /></a> <span style="font-style: italic;">SD cards are used in many cell phones</span>.<br /><br /> Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive. <br /><br /><span style="text-decoration: underline;">INSTRUCTIONS</span><br /><br />1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card. <br /><br /> 2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter. <br /><br /> 3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.<br /><br /><br /> </span>
on Jan 28, 2011 | Cell Phones
I have pics on phone photo album and want to transfer them to micro sd card. can't get the computer to recognise to transfer by usb.
try
http://cgi.ebay.com/Micro-SD-TF-M2-USB-adapter-card-reader-up-16gb-/220718102304?pt=PCC_Drives_Storage_Internal&hash=item3363d2f720
Jan 16, 2011 | LG RUMOR Cellular Phone
How do I transfer my pictures from my Samsung phone to my p c?
You will need the SD mini memory card and an adapter, Install the mini card in the phone and copy the pics you want to transfer, then use the adapter in the computer to access the pics., or you can e-mail them to yourself and access your e-mail from the computer.
Oct 16, 2010 | Nokia 6233 Cellular Phone
Cannot get pics on sd micro card
take out the microsd card from phone, and then use an adapter which will convert microSD to USB. They can easily be found on eBay
May 07, 2010 | LG VOYAGER VX10000 Cellular Phone
How do i transfer pictures from cell phone to laptop?
two known options:
-email photo to yourself from the phone.
-this phone seems to have a micro sd card slot - you can insert a micro-sd card and transfer the photos to the card, then read the card on the laptop with a reader that supports micro sd.
so, you should check into the laptop and see if it has any card readers built in since you may need an additional adapter or device in order to connect the micro sd card to the laptop.
some micro sd cards will come with adapters to the larger sizes of mini and standars sd card, which may help.
you might also have luck putting the card from the phone into some other connectible device (ie a camera) and move the files in that manner - but depending on your hardware and software this may not be a viable option (inexpensive to try, though, if you already own some compatible device)
Nov 01, 2009 | LG RUMOR Cellular Phone
Micro SD adapter doesn't work
try asking other people how to work it because im a brainiac and i could probly get the answer
Oct 05, 2009 | PNY 2GB microSD Memory Card
Where do you put the sandisk into?
the micro SD(smallest) goes into the phone the other 2 are adapters, mini for older PDA's, the largest goes into your PC (usually on newer models), if the pc does not have a slot for the sd, use a usb adapter to transfer music
Feb 14, 2009 | LG RUMOR Cellular Phone
Can I transfer pictures from my computer back to my chip
If you have a micro SD card that has an adapter for your computer you can plug it into your computer and open it inside an explorer window and drag and drop pictures from your computer folder to your picture folder on the micro SD card. You can definitely do it. I just did it for a friend of mine and it works perfectly. That's why they sell the micro SD cards with the adapters for your computers...so you can transfer things back and forth. Mine is the 8GB Kingston that comes with adapters from micro to mini to regular SD card and to USB port. I bought it from Newegg.com for under $20.
Nov 27, 2008 | LG VOYAGER VX10000 Cellular Phone
From cell to Pc
Hi Big Bran,
There are 4 methods to transfer pics n videos from mobile to pc. They are through :
1) Bluetooth
2) Infrared Device
3) PC suite via USB data cable
4) MMC reader. ( memory card reader)
I think u r new user of this mobile phone. For u, I recommend u to use Memory card reader. It is very easy and fast.
Process : Take out memory card of ur mobile and insert in the MMC reader. ( It is easily found in the market and they provide u with adapter like a micro SD memory card to insert ur mini Memory card in it ). Join the MMC reader fitted with ur MMC in PC. Now, it shows a new drive like as CD drives. Now copy or transfer pics or mp3s or videos via it like u do in other drives(pen drives, floppy drives).
I think u may have mini Memory card. For it to be fit in MMC reader, u need a small casing adapter which is like a micro SD memory card. INsert ur MMC in it, and ur drive will be shown.
Looking for ur kind feedback,
SAJAN (sajwhat_2003@yahoo.com)
May 05, 2008 | Motorola Mobility RAZR V3
PNY 2GB microSD Memory Card Logo
80 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
