Question about Ricoh Aficio 2232C Color Copier
Ricoh 2238c prints white spots all over the page in BW. In color it prints the black areas very lightly. Changed Black toner and it did not help
    Problem Solver:
  • 6 Answers
Sounds like you need a new dev unit or drum possilbly both.When was it last serviced?
Posted on Nov 17, 2009
Testimonial: "Thank you problem solved. Changed both and works like new."
  • Ricoh Master
  • 1,297 Answers
Change the black developer or perform the developer initialization setting.
How do I print out toner usage coverage report. average coverage per page colro vs bw
depending on how much color or black you print per page, you control that, you didn't state the make and model to help your with that question
Dec 02, 2015 | Office Equipment & Supplies
Toner does not load in Ricoh 1900 BW copier
Did you pull the tape/pull-tab off the new toner cart?
Oct 06, 2015 | Ricoh Aficio 2238C Black Toner 19000 Yield...
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
Black spots on paper - Ricoh Aficio MP2000
If it uses a cartridge, check for leaks. If a leak is found, there may be toner scattered inside the copier
Oct 11, 2012 | Ricoh Aficio MP 2000 Black and White...
Konica Minolta Bizhub C552 is counting Grayscale pages as color.
I changed my image/graphic into a bw bitmap image. It worked for me. I get charged one side color and the other side bw.
Aug 21, 2012 | Konica Minolta Bizhub C552 Color Printer /...
My Ricoh SP 232sf wont print at all because the K toner is out of toner but it has plenty of color. Can I force it to print somehow?
Unfortunately, no, the printer won't print even in color if the black toner is empty. The black drum rotates whether the copier is printing in black & white or color, so if black is empty you can't print at all.
Feb 23, 2011 | Ricoh Aficio SPC232SF All-In-One Laser...
Ricoh CL3500N not printing black?
Sounds like the Dev unit is about worn out. May also be a transfer issue.
Nov 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Gestetner DSc224 starts to print black strips inside colorpages
the printer in the service program has a option for the printer to do a process control on selected number of copies that number for your machine should be lower because you print about 150 duplex pages an that is 300 single pages so go in the service menu and set the process control on some 30 pages to be done .
Follow the next procedure:
- For to enter the service mode:
1. Press the clear modes key(the yellow key)
2. Type “107” at the numeric keypad.
3. Press the clear/stop key(red key)
and hold it down until the screen
display changes (for about 3 seconds).
4. Touch “Copy Sp” on the touch screen.
In the upper right corner on the touch screen has a key named [Sp Direct],touch that key and enter with the numeric key pad the numbers:3003 and on he screen will appear [Lubricant Interval] set the interval on 30 pages and press the "#" key for to confirm the value. After that for to return to normal mode press the exit key on the touch screen several times.
Also do the [maintenance -clean/adjust] option once after 1000 or 500 pages printed. Because this is a office machine and when you print on her a lot of pages per day the machine start to get dirty.
PLEASE RATE ME IF THIS HELPS
Aug 09, 2008 | Gestetner DSc224 Copier
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio 2232C Color Copier Logo
225 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
