I have a beko washing machine model WMA520S, i have had it for 3 years now on the second machine after the same fault bearings and concrete block falling out causing the machine to not spin and leaving water in it. now the machine is not spinning again took the back off the concrete block hasnt dropped but there is the black ash stuff on the floor is this the same problem again?
  • 3,741 Answers
Yes its the same but bearings can be replaced.they are available.you can get replacement parts from
www.repairclinic.com
also the otherpossibilities that machine not spinning are
click this link directly
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
Posted on Nov 16, 2009
Small water leak from under the washing machine
not un common for manufacturers to test every 5th , 3rd , 10 th machine if yours came with a defective/ cut/ or otherwise failed pump to drain hose or tub to pump hose. my 15 years in the business hint noisy in spin points at unseated main tub seal/bearing call for factory service don't void warranty by fiddling with it your self ( maybe an easy fix slipped hose,maybe a 3 hr repair for a qualified journeyman appliance technician.
Oct 24, 2016 | Beko Washing Machines
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Beko WMA520s door won't open at end of wash!
turn off and hold door in for 2 mins
Apr 08, 2015 | Washing Machines
Beko washing machine faults
press and hold start for 3 seconds or more to cancel
Feb 05, 2014 | Washing Machines
Beko 510w
the beko washer sometimes the concrete balance blocks come loose and cause a banging noise unplug and take the top off check the concrete block on the top off the outer drum to see if it moves about tighten it up if loose then check the one down the front to see if louse
Sep 20, 2012 | Washing Machines
Beko washing machine belt keeps coming off
Possible that you need to find out if the replacement belt is the OE type or there is a fault on the quality.
Please check this site. www espares.com for spares
Jun 05, 2012 | Beko Washing Machine Belt 2005170400...
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Beko wma520s start button flashing will
problem sorted by removing filter drain plug very slowly to empty machine of water and any blocked residue. check drain hose is not kinked. reset machine and rinse through on empty ie no washing.
Mar 31, 2008 | Washing Machines
Washing Machines Logo
297 people viewed this question
Top Washing Machines Experts
