Question about Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
Drill starts and stops like there is something loose on the inside
    Problem Solver:
  • 17 Answers
This is typically caused by one of two things. Worn brushes or a bad switch. How old is drill and has it been used a lot? If the brushes are worn/bad they will need replacing. If the switch (trigger) is bad it can sometimes be fixed by spraying an electronic contact cleaner in it. This cleaner can be purchased at Radio Shack. I have also had good success using WD40. Spray the switch down good (power removed) and manually operate it a few times, wipe it clean, plug it in and try it again.
Posted on Nov 16, 2009
My Ryobi PD750 impact drill just stopped working! Is there a safety button or something that could prevent it from working? Ive tried other plugs. Its fairly new.
The wires on the brushes sometimes shake loose , tool repair shop ,, or try it yourself ,, remember. Small parts ,, take pictures , tiny wires , may need to be soldered back in place ...
Jun 11, 2017 | Ryobi Drills
Bosch 18 2-L. I press the button, led light comes on but drill is temperamental in any setting? It works, sometimes not or stops halfway through. Any input would be greatly appreciated. John
none of them will last forever being used in dirty work conditions .and from your picture it looks like drywall dust . one of the worst things on drills . gets in the insides and eats them up you can try blowing it out with compressed air daily but do not hold your breath it might help for awhile but the drill is dying slowly
Aug 29, 2015 | Bosch 23618 18V Cordless Impactor...
Bosch 36 volt drill smoking
armature blow up ? or only loose wires slide contacts on the switch .
May 04, 2014 | Bosch Drills
Not getting power
Return right away. Your diagnostics tell me unit is bad.
Jun 04, 2017 | Drills
When tighten, keyed drill chuck gets stuck
Did the left hand screw inside the chuck come loose? This happens a lot and when it does the screw will back out a little and block the jaws from closing. If not I use dry graphite lube.
Mar 30, 2012 | Black & Decker Drills
Makita will not stop hammering
HELLO TRY TAKING THE SELLECTOR OFF AND SEE IF THE LOCATOR PIN HASCOME OUT IF THATS NOT THE PROBLEM YOU MAY HAVE TO GO DEEPER UNDER THE SELLECTOR TO SEE IF SOMETHING IS LOOSE OR WORN.
Nov 25, 2011 | Drills
Porter cable hammer drill 987 suddenly stopped running.
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
Drill works in only one position
You most likely have a loose connection inside somewhere, when you turn the drill to another position it creates a gap in the connection, therefore breaking the circuit.
Jun 05, 2010 | Black & Decker 1/2" 13MM, Heavy Duty Vsr...
Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
158 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
