Question about Acer Aspire 4520-5582 Notebook
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
  • 458 Answers
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Posted on Nov 16, 2009
Testimonial: "Thank You very much.......Looks like I have a faulty DC Jack. Greatly appreciate the quick response......."
AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
So your saying the charger will charge the battery, as long as the laptop is off...But when it is charged, you remove the ac adapter, start up the laptop, running on battery power alone, then hook the ac adapter to it, and the laptop cuts off..???
Apr 27, 2014 | Acer Aspire 8930G Laptop Charger...
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
Jun 14, 2011 | Acer Aspire 5920-6706 Notebook
My acer aspire 4520 all of a sudden would not turn on one day. When the power button is pushed, the little battery light in the left corner on the bottom of the keyboard will flash orange and nothing will...
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Dec 27, 2010 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
Sep 06, 2017 | Acer Aspire 4520-5582 Notebook
Hello all. I am currently the owner of an Acer Aspire 4520. Lately, I have noticed that it is not coming on as it should. When I press the power button, it turns on for a few seconds, and then turns off....
I'm having tha same issue with my 4520. I found the service manual at this link. http://printer1.blogspot.com/2008/01/acer-aspire-4520-service-manual.html
It has a good troubleshooting and dis-assembly procedure. Unfortunately, mine loks like a bad motherboard. If you find a solution let me know.
Jan 06, 2010 | Acer Aspire 4520-5582 Notebook
Will not Charge and will not work on AC power alone either....... (Acer 4520 Laptop)
most probable the inside contact which receives the charger is broken or the charger is broken. go to a service and test them both
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520-5582 Notebook Logo
157 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
