Question about Bosch Dryers
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
This is happening me too. Have you had any suggestions how to solve this problem???
Posted on Oct 11, 2010
The secret to fixing this problem is accessing a hidden panel in the recess where the condenser unit, not the water container, sits. I have a Bosch Classixx condenser dryer which has this hidden flap but it seems many bosch condenser models have it. Make sure the unit is powered off. I left it plugged in but was careful not to power it on during the clean. When you pull the condenser unit out, which is on the front of the dryer, on the left hand side at the bottom, the hidden flap is flush with the bottom of the recess where the condenser normally sits. Run your hand along the bottom of the recess and find two flanges towards the back. It opens like a remote control, or standard battery compartment. I was frustrated to get the flap open, as you can only get one arm in the recess, and there are two flanges. You need to work on one at a time. I found the right flange easier. Used my forefinger to pull it towards me and my other fingers to find the edge of the panel and force it up a little. This is enough to off centre it which then prevents it from falling back in whilst you do the other side. Reach into the new opening and pull out the gunge. Shove a dishtowel into the opening to sop up the water. Reach to the back of the recess and beyond and pull out a big pad of compacted but mostly dry fluff whilst you are there. Put the panel back in, replace the condensing unit and feel proud you fixed it. Goodness knows why this isnt mentioned in the manual, or why it is so hard to access yet has an official entry point. I think its to keep the repair men employed!
Posted on Dec 20, 2014
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Tumble dryer stops container light flashing however container is empty
see this possible causes:
Belt
belt break, the drum stop, replace belt
Motor
motor burn, howoeve take out the belt, and try to turn by hand if the motor is easy to turn the motor is o.k and the contrary. replace
Door switch test the swtich, see the diagram
Jun 14, 2012 | Bosch Dryers
My bosch classixx 1400 express washing machine stops at spin cycle..
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 19, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Dec 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dryers Logo
2,482 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
