Question about Sony KV-35S42 35" TV
Contrast when i reset my sony kv28sl35u contrast to factory settings whitecolours seem to appear as pink, and i get a pink shadows on the screen
    New Friend:
  • 76 Answers
This is due to screen control faulty or crt weak. Change the screen control and its related coupling resisters.
Posted on Jun 24, 2008
WHITE SCREEN ON SONY BRAVIA
I wold open up the tv, reset the T-conn ribbon cable. If no fixed then the T-conn is to blame.
Hope it helps.
Jun 22, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
Prs 600 ereader screen contrast problem
The PRS-300 "Pocket Edition" ereader is a device that did provide a far better than ... I bought the Sony Reader Pocket Edition to use for my public library's downloads. ... Conservatively, I probably read upwards of 20 hours each week, both ..... Well lets just say it only seems like there are a few words on the screen at a time. ...
Jan 03, 2012 | Sony Reader Touch PRS-600
I have let a friend borrow my j750 and now i turn it on and a blank screen appears and is frustrating
you need to reinstall its software.
for this contact with mobile repair shop.
2nd thing is contrast, factory reset your mobile for reset your mobile contrast.
Jul 06, 2011 | Samsung SGH-J750 Cell Phone
Uncentered image using projector
reset the settings to factory default. is it cut off evenly, or is it uneven and shadowed? if it is the latter and you have a dlp projector, you have a collapsed light tunnel. if it is cut off evenly, go into the settings and make sure the resolution and screen size matches.
Jan 27, 2010 | Sony Office Equipment & Supplies
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Black screen
check the brighness and contrast of the monitor from the menu button ... try giving reset ....
if same problem persists then the monitor CRT tube may be gone
jsut go expert technician and tell the problem...
if so the technician will recharge the tubes...
Nov 17, 2007 | Sony SDM-HS73P 17" LCD Monitor
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Sep 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Color shadows
PVAT!Check for evidence of coolant leak on pcb's, If none found,replace convergence IC's,then align convergence in servicer mode.Check service literature for procedure.
Sep 02, 2007 | Hitachi 60UX58B 60" Rear Projection...
Sony KV-35S42 35" TV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
