Question about Sharp AR-5316 Advanced Digital Imager Copier
NEED PART NUMBER FOR SCANNER UNIT FOR AR 5316
NEED PART NUMBER FOR COPIER SCANNING UNIT FOR AR 5316
  • service368 Nov 16, 2009
    I need the scanning unit that goes back and forth when making copies not the laser unit.
    President:
  • 1,335 Answers
I need the driver SHARP AR 5316 SCANNER COPIER PRINTER
You can download the driver for sharp AR 5316 Advanced copier from the following link which can be installed on a Windows XP Platform.( http://www.nodevice.com/driver/AR-5316/get47086.html ).Visit the link - Enter the verification code shown on the box below and click Download.The download will start in a few seconds.Your valuable feedback would be appreciated.
Jun 04, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Check
and
remedy
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar 5316 copy lamp off
You may have to replace the lamp unit...but ... I would first make sure all connectors have been re-seated.
Remove the main glass and make sure all ribbon/wire connectors are unplugged and re-inserted. (make sure copier is off). You could also remove the back cover of the copier and unplug/replug all connectors just to be sure.
You never know !
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
5316 SCANNER DRIVER
the sharp 5316 does not work as a scanner
sorry for that
Feb 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-5316 SHARP COPIER
Could be the scanner or the USB cable. Do you have replacement USB cable?
Jun 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar5127 copia eror slution
Check the scanner lock located under the scanner section on the left side. Change the position of it.
If it sitll locks the scanner could be jammed up by the cable. The scanner glass has to be removed to fix that.
Jun 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Problem
L1:SCANNER UNIT FORWARD MOVEMENT PROBLEMS,POSSIBLY BAD SENSOR, SCANNER MOTOR, OR BOARD I would check that the transit screw that holds the scanner in place hasn't reconnected. The second thing is to lift up the glass and check that you can drag the scanning bit (the mirrored bit that moves) across. That should sort it.
Aug 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
121 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
