Question about HP Pavilion zd8000 Notebook
Video card problems
I recently turned on my computer and during startup I noticed broken colored lines (Strips) running horizontally across the screen. When It loaded to desk top, the lines were still there but only at the top third of the screen. However, when I started working on line or with applications such as word and scrolled down the page, the line became solid and followed the scroll down. Sorry it's hard to explain....Is the ATI Radeon x600 failing??
Any help would be appriciated. I'm serving in Iraq and have no support options.
Thank You
Pressing on the screen doesn't effect the lines other then a slight distortion from pressing on the screen.
Thanks for your input.
Posted on Jan 12, 2008
To press on the screen doesn't effect the lines. Other then a slight distortion due to pressing on the screen.....
Thanks for your response....
It Needs the BGA RAM reflowed period.. Trust me.
www.ikenfixit.com
Posted on Jan 11, 2008
  • 589 Answers
If you were to gently "squeeze" the screen bezel where the lines are, do they go away, or get worse?
Posted on Jan 09, 2008
    Sergeant:
    Champion:
  • 317 Answers
Sounds more like the screen has a spot in it where the circuitry is bad, easiest thing to do, is take it to a repair shop and see if they can fix it, if not, call the manufacturer, and see if they can get you a new one. Usually they will, since it will be considered a defective product.
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
Rolling Horizontal Lines across the screen
ground loop is problem. Many answers available via Google.
Jul 07, 2009 | Acer AL1916W 19" LCD Monitor
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
My printer will not print color
Hi.
First check if u r using compatible cartridges for your lexmark printer. You may use the following weblink to find the comaptible cartridges for lexmark printers:
If using correct carts and stil issue, then check the below info to clean the print contacts and cartridges:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier.
Try it out..
Apr 24, 2009 | Lexmark X2500 All-In-One Printer
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Vaio SZ640 restarting on it's own.
you may need to re-install the driver of the video card or at least update it. else this immediate restart may mean that the Laptop is overheating. check that the fan is working.
Mar 17, 2009 | Sony VGN-SZ640 Notebook
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Horizontal line throught the screen.
Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Nov 12, 2007 | Gateway FPD1975W 19" LCD Monitor
Lines like strips horizontally across the LCD !!!!!
I had same problem. Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. Camera instantly worked like it used to. Good luck.
Dec 01, 2006 | Sony Handycam DCR-TRV30E Mini DV Digital...
HP Pavilion zd8000 Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
