Question about RIM BlackBerry Bold Smartphone
When I click to sync my Blackberry with my PC I'm getting a message reading: Error Encountered. Error code 0x8004fd28. Check documentation
My mobile phone was being locked can try this
Posted on Nov 16, 2009
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
I just cant get my blackberry curve to pair or sync
Do you have blackberry desktop manager with you.If you have connect your phone with USB Cable to pc then start the application in your PC then click OK if you receive any warning message.
Type the password of your cueve device.
Click the "synchronization" option in the column of the left side of the screen and then "synchronization" button on right
Type the password if you configured in your phone
Select data which you want to sync.Contacts,messages etc will automatically sync,
I hope this help you
Thank you
Sep 30, 2010 | RIM BlackBerry Curve 8310 Smartphone
Jum error 102 on new blackberry bold phone is frozen with white screen and message 'jum error 102'
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 14, 2010 | RIM BlackBerry Bold Smartphone
Blackberry curve won't upload photos to facebook. have tried resetting mobile settings on fb, but still doesn't work. I keep getting error message: ''There was an error uploading this photo''
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, such as this.
Jan 08, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I get an intellisync error 0x8004fd28 when trying to Sync my blackberry
Hi, When attempting to synchronize between the computer and the BlackBerry smartphone, the Error 0x8004fd28 message appears on the BlackBerry Desktop Manager. This is due to the intellisync folder is corrupted. To resolve this issue, you need to complete the following steps: 1. Close BlackBerry Desktop Manager. 2. On the computer, navigate to the appropriate folder listed below: · If you are using Windows® XP, go to C:\Documents and Settings\\Application Data\Research In Motion\BlackBerry\Intellisync · If you are using Windows Vista?, go to C:\Users\\AppData\Roaming\Research In Motion\BlackBerry\Intellisync Note: If you are unable to view the above folder refer to additional information section on instruction on how to view hidden files 3. Delete the Intellisync folder. 4. Open the BlackBerry Desktop Manager. Note: If the BlackBerry Desktop Manager attempts to synchronize at this stage, synchronization will fail. 5. Configure the BlackBerry Desktop Manager for synchronization by completing the following steps: a. Click Synchronize. b. Click Configuration. c. Click Synchronization. 6. Synchronize calendar appointments. OR If there are one or more corrupt entries on the BlackBerry smartphone . Take back up and clear the database on the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry storm says it won't support facebook. I changed to blackberry desktop for mac and now I have error messages when I sync apps.
Nov 06, 2009 | RIM BlackBerry Storm 9530 Smartphone
Sometimes the videos play and other times they don't. The media player will load and the video just won't play' Once in a while I will receive an error message.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like the error message you receive.
Nov 05, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
JVM Error 545 - Blackberry Pearl 8110
to correct this issue try this method
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Aug 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Email that has been read on my pc is showing up unread on my blackberry is there any way to sync?
It can take a while. I waited 10 minutes before a message on my blackberry goes read.
If you go into you messages,click the blackberry button and scroll down to reconcile now. This should speed up the process.
Also if you goto options in the same menu and scroll down to email reconciliation, you can change how your device handles email deletions and conflicts.
Aug 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cannot download
Make sure you are trying to sync .MP3 or .WMA files.
If this is the case check out the error code number on the Microsoft website.
Feb 24, 2008 | Philips GoGear Flash MP3 Player
RIM BlackBerry Bold Smartphone Logo
91 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
