Question about Samsung LNT5265FX 52 in. LCD Television
When turning on my Samsung lcd i get a few
When turning on my Samsung lcd i get a few seconds of a soft buzz then get audio only no video and the black screen only
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 16, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Model LN52A550P3FXZA. Video and audio cycle on and off every 30 seconds or so. When picture switches off, the screen is filled with multi-color horizontal lines.
It is a common problem for this model, the problem is the main board. There are 2 Tantalum capacitors (C102 & C131) 47MF/10V, 1 Passive Voltage regulator KIA7805AF (IC300), 1 Step-Down Power Conveter IC MP2363DN (IC101) need to be replaced. If you do not have soldering skills, just order a new board.
May 16, 2017 | Samsung Televison & Video
My Samsung HL-P6163W loses its picture but the audio still works. I thought maybe the lamp was bad so I purchased a new lamp. After I installed new lamp it still will not work. I can see it trying to turn...
It's possible that the lamp connector (usually attached to the ballast module) has bad contacts. I had a similar problem that I solved by polishing the contacts with a strip of Scotch-Brite metal polishing fabric wrapped lengthwise around a small screwdriver. Note: I don't like to use sandpaper for this; it will remove the plating on the contacts and make it more likely that the problem will happen again soon.
Jul 08, 2017 | Samsung Televison & Video
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming...
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming from the back of the unit.
Nov 15, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung LN-t5265f picture turns off after a few seconds hear buzz
You have a bad Power supply. Have a trained Samsung tech replace the Power Supply.
Jul 02, 2009 | Televison & Video
My Samsung LCD television loses audio for a few
maybe the amplifier circuit is loosing try to resolder and checked the capacitor in the amplifier circuit.
Mar 28, 2009 | Samsung LA40A450 40 in. LCD TV
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Camera not working
That soft buzzing sound seems to me would be the power supply inside the camera trying to operate something under a loaded condition like maybe ba stuck iris or lens or could even be those small caps (we call them Pan caps)inside your camera are starting to go bad. unless your quite good at micro electronics I would leave this one for the pros.. Contact the sony service depot in your owners manual.
Apr 19, 2006 | Sony Handycam DCR-TRV840 Digital Camcorder
Samsung LNT5265FX 52 in. LCD Television Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
