My washer is leaking...
Hello!
My washing machine is leaking water from underneath the machine. I have checked the rubber washers and they are fine. Please help me...I'm trying to be Martha Stuart and Mike Holmes in one and getting no where fast.
The brand of washer/dryer is: General Electric Spacemaker. They're stackable.(If that helps.)
Thanks for your help,
Kate Paylor.
  • tkmjrm Apr 10, 2008
    My Bosch Nexxt stackable washer is leaking from the bottom only during the rinse cycle.  Advice?  It is one year old.
  • dd03im Sep 27, 2008
    My spacemaker washer is leaking water from the rear lower right pump access port (drip drip drip adds up). There has got to be a seal thats not doing its job. How do I fix.
    Scholar:
  • 196 Answers
There are several items that can leak on the inside. I may be of some service to you. I need to know the model and serial number so I will know wich machine is being worked on.
Posted on Jan 09, 2008
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Water leaking underneath
hello you may have a hole in the door seal open the door check the rubber door seal, if this ok the check the hose that connects to the pump
regards
shaun
Aug 30, 2010 | Whirlpool LHW0050PQ Front Load Washer
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from underneath washer
my washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
