Question about Jura Capresso Impressa S90 Espresso Machine
Error Code 8 The machine won't make coffee and keeps trying to eject a puck over and over before it stops and Error Code 8 shows on the display.
I have experienced this same fault code a few times. Actually it is just some stray beans that are not allowing the puck compressor to make its full stroke. Solution; Remove the water tank.. Turn unit on it's side and remove coffee beans. Turn unit over til it is resting on it's top. Shake and bang on unit to dislodge stuck beans. Upright unit, replace water tank and add beans. Enjoy coffee.
Posted on Mar 25, 2013
I have the same problem..... you have a faulty brew unit... you will need to send your unit to Jura USA for repair..... I know this the hard way as I cant get them to sell me the darned spare part....
Posted on Jun 11, 2010
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
This error is shown on the display due to:--
Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
This Will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
How to fix error message 8
DISPLAY SHOWS MALFUNCTION 8 Solution: Turn off and unplug machine. Wait a minute. Turn machine on and wait until it stops making any noise. Now try to pull out the drawer. If this does not work, try the procedure again. If this does not work, call customer service
Regards Kat (please leave feedback, many thanks)
Aug 19, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Machine won't work due to dreg drawer
Check to see if your machine has an "exit chute" or similar area where from the used pucks are ejected. The area might be clogged with used coffee grinds and causing a false reading from the machine.
Dec 14, 2009 | Saeco Royal Digital Plus Coffee...
Why are my ejected coffee pucks very wet? Seems
You need to be sure the removeable grinding surface is clean and not clogged. If it is not clean, water has problems passing through the screen and the water cannot escape, staying in the puck...
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Malfunction 8
I just fixed it. I saw some info from a Doctor in Hawaii who described reaching up inside the machine with some success and this inspired me (Thanks!). I had been getting Malfunction 8 for some time, and letting the machine cool (turning it off) for 15 minutes was the only way to not get the error. It always sounded like it was "straining" to make coffee. It would generally try 3 times to clear itself before the Malfunction 8, I'm sure those with the problem will recognize the symptoms. All the rinse/ decalcify/on/off stuff was temporary. We lived with this for 5 months or so. Finally, it would only get a Malfunction 8, and so became unusable, and we were considering sending it in for repair. This was the second round of Malfunction 8 problems; the first seemed to fix itself for an unknown reason. On to the fix: Unplug, remove the water tank, pull out the bucket and tray, and allow to cool if necessary. Now - smaller fingers are better - reach into the machine, palm up. Feel as far back as you can, then work your way forward, toward yourself. As you move toward you will feel a flat area about an inch wide (measuring front to back). Just back of this (away from yourself), you'll feel a crack about 3/8" to 1/2" wide. Push your fingers up into this area and feel around. You will probably feel stuff that feels like light, chunky rocks. Break these up and they should fall out. Again, small fingers are better and once I got an idea of what I was doing, I described it to my wife and she did it. There is a tendency to not feel far enough back in the machine, so be sure to find the flat place at the lowest point of the mechanism then go just past it and up to find the crack. Pulled out about five crusty chunks of burned, almost charcoal like compressed coffee. I also got about a foot of plumber's tape (the metal stuff with holes in it that's useful for just about everything) bent it with a 4" radius, and worked it up into the crack to break up any stuff we couldn't reach. Work at this until no more stuff is in there. Now, tilt the machine toward you and "pat" firmly all over to jog anything left into the crack area, and check for chuncks again. When that's done, put everything back together, move the machine to where you can work from the top. Don't start it up. Get a flashlight and a wooden spoon. Open the top "pre-ground" door and peer in. With the wooden spoon handle, poke in there and tap everything to break up any stuck things. I thought a shopvac with a small tube might work here, too, but wasn't sure whether something bad might happen. Anyway, tap tap tap about 100 times. Now start up the machine. Keep peering in; watch how the mechanism works, and don't trap the spoon handle! Now, try to brew some coffee. While it's actually squeezing out the coffee, tap some more on the "closed" mechanism to free up any more stuck coffee. Do this whole procedure 3-4 times to be sure, but don't drink any of the coffee it brews: The first ejected puck looked really aweful - it looked like about 1/3 moldy coffee; of course the machine had been sitting for 3 weeks, probably stuck in the middle of a puck ejection cycle. Anyway, the machine should run good as new. Good luck and please comment as to whether it works for you. - Woody
Aug 25, 2008 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso Impressa S90 Espresso Machine Logo
2,281 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
