Question about Ascaso Dream Espresso Machine
Just need to find a new head gasket (black rubber ring). any sources (november 16, 2009)
  • 1,089 Answers
Hi
Check with
http://www.seattlecoffeegear.com
or http://1st-line.com/
Posted on Nov 16, 2009
Oil leek 2005 Aveo
sounds like they didn't do the heads properly
Mar 06, 2014 | Chevrolet Aveo Cars & Trucks
Excess smoke
The general rule: white-ish smoke indicates coolant in the exhaust, meaning a blown head gasket, whereas darker smoke indicates motor oil in the exhaust, which means that one (or more) cylinders have a broken ring, and the engine needs a ring job.
Fix for white smoke: replace head gasket.
Fix for black smoke: ring job.
Oct 05, 2011 | 2003 Lexus ES 300
I havea daewoo nubira and we replaced the valve cover gasket yesterday , did an oik change and now the engine is smoking white smoke. Try to check to hoses, could not see a leak. Where is the cylinder...
Hello and welcome to FixYa!
The cylinder head is located on the center of the engine. Yes it can be a worn out head gasket or piston rings. If the piston rings are worn out the oil is burnt that's why it emits white smoke. You will need to replace the head gasket and piston rings.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 30, 2011 | 2000 Daewoo Nubira
Bike is reving but losing power
The loss of power is usually due to the need for a valve job. Do a compression check. If compression is lower than 120 psi a valve job is called for. While you have the head off, install new rings. Considering the age of the bike, a new cam chain would not be a bad idea as well. Another possibility is a lean fuel/air mixture; If the bike has an idle speed that you can not get to slow down then there is an air leak letting un-carbureted air into the mix. Cracked rubber seals or bad gasket on the intake manifold would be the likely source. tombones49_50.gif
Apr 03, 2011 | 1993 Honda CB 250 Nighthawk
Water leaking out of the bottom of the pump - low pressure leak, light stream
Will be a gasket, o-ring or seal that has blown. Could even have a cracked fitting or a split hose.... remove housing where leak is coming from and inspect. call service part agent and order new part (make sure you grease seal or o-ring with rubber grease. If it is a gasket you may need to use a gasket sealant and find out what the torque setting are for the component you have disassembled.
General quide is: 10mm head = 10 - 12 newton meters 12mm Head = 18-20 newton meters
Hope this helps... hard to diagnose accurately with your vague description
Feb 10, 2011 | Karcher 2500 PSI Pressure Washer
My son replaced the thermostat and thermostat housing on his 2002 ford taurus. It is leaking from the bottom of the housing. What would cause this?
COULD HAVE DAMAGED RUBBER O RING TIGHTEN TOO TIGHT OR REUSED THE OLD ORING WILL CAUSE LEAKING.IF YOUR THERMOSTAT HAS PAPER GASKET INSTEAD O RING. YOU NEED TO PUT SEALANT ON BOTH SIDES OF THE GASKET.THAT WILL KEEP IT FROM LEAKING.IF YOUR VECHICLE HAD A RUBBER O RING AROUND THERMOSTAT REPLACE WITH NEW O RING DONT PUT PAPER GASKET IF YOU HAVE THE O RING SEAL.THE O RING DOES THE SEALING NO NEED PAPER GASKET.
Jan 13, 2011 | 2002 Ford Taurus
The handle is leaking water
Hi
Your brew head gasket needs replacing. They get hard after about 6 months to a year depending on how long the machine is on. if it on 24/7 it need to be changed every 6 months. If turned off daily every year. The gasket is up where you install the portafilter to make espresso. The black ring is rubber and that is what need to be changed. Have one setting right here on my desk.
Nov 09, 2009 | Pasquini Livia 90 Espresso Machine
2004 DODGE Ram 1500 4.7 truck runs rough black smoke, low vacuum
Search for vacuum leaks. Could be your head gasket, or oil rings. Black smoke = oil is being burned. Which would mean that either your oil rings are worn out (for whatever reason, since your truck is fairly new) or that you have a head gasket problem.
Jun 04, 2009 | Dodge Ram Pickup 1500 Cars & Trucks
Ascaso Dream Espresso Machine Logo
528 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
